Ok guys, you all have helped me greatly with my project truck so far. Now I have one last problem. I have an '88 f150 5.8. My reverse lights won't light. The wire is good, the other lights light. It is automatic, my guess is a bad switch in the column. I need to know where I can find a lighting wiring diagram in PDF so I can put in a switch. PA requires that I put in a switch I know what wire, just need to figure out were to splice in. Thanks again guys..
The switch is on the side of the transmission at the selector lever.
The power going in is a Purple wire with a Orange stripe and the wire leaving to the back end is a Black wire with a Pink stripe.
