Sponsored by: Auxito
still knocking
Old Jan 14, 2007 | 01:59 PM
mad mech's Avatar
mad mech
still knocking
my 97 f150 4x4 4.6l v-8 is still knocking. changed the oil,oil filter, and spark plugs.that semed to help a little.after starting it up, i took a mech stethascope and went all around the front,top bottom and both sides of the engine.could not find the knock.when i went to the transmission,ifound some ticking around the torque converter.could i have a problem there instead of the engine? thanks in advance
Old Jan 14, 2007 | 04:39 PM
ReAX's Avatar
ReAX
It's possible, but the parts of the trans rotate so it should be more of grinding or swirling sound. The motor has the bulk of the reciprocating parts. I have two suggestions to try, 1 a heavier oil, 2 lucas oil stabilizer. It reads like snakeoil, but lucas makes some good products.
Old Jan 14, 2007 | 05:26 PM
monckywrench's Avatar
monckywrench
I second the Lucas recommendation. It's buying me time on a dying smallblock Chevy right now.
f your problem is alleviated by it, then you know you have internal wear problems.
Sabertooth
Jan 2, 2022 08:39 AM
blue924.9
Jan 28, 2014 09:11 PM
fordman19762003
Modular V8 (4.6L, 5.4L)
Dec 6, 2012 10:50 AM
74 F350 SCS
Aug 25, 2012 07:15 AM
sitiakab
1997 - 2003 F150
May 29, 2012 05:50 AM
