Help!!
Old Jan 14, 2007 | 11:42 AM
fordexcursion182's Avatar
fordexcursion182
Question Help!!
I recently went out and started my 2003 Ford Excursion. It hasnt been runned for about 5 months.. When i put it in drive the emissions light came on, but i ignored it till i reached 40mph and the truck started hesitating and shaking.. Any ideas on what might be wrong??
Old Jan 14, 2007 | 02:42 PM
Monsta's Avatar
Monsta
Sit. Stay.
It was probably pissed that you haven't driven it in so long.
Start with the basics.
~Fuel up with fresh fuel. Add Sea Foam to the fresh fuel if you like.
~Check your air cleaner to make sure something didn't make a nest in there!
~Check the exhaust for the same.
~Change your fuel filter. It's cheap and easy. Make sure you get the removal tool from the parts store when you're there. (If you've got a gasser.)
Could be a clogged injector(s), too. Sea Foam should help with that.
At least one good thing is that the light is on. That means there is a code stored that could help you troubleshoot the problem. Most parts stores will scan the PCM for free.
Old Feb 27, 2007 | 07:47 PM
fordexcursion182
Thumbs up Thanks
It worked out acculy pretty well. It turns out that od sensor was just wacked becasue of the old gas in it.. Thanks again
cv
Old Feb 27, 2007 | 07:52 PM
Monsta's Avatar
Monsta
Sit. Stay.
Overdrive sensor?!?
Well...anyway...glad the truck is back to normal.
Old Feb 27, 2007 | 07:53 PM
fordexcursion182
yeah, thanks again, I appreciate it
Old Feb 27, 2007 | 10:08 PM
Btravelen's Avatar
Btravelen
Originally Posted by Monsta
Overdrive sensor?!? ....................
That musta been it.
Take Care
