302 engine replacement
Old Jan 14, 2007 | 09:40 AM
yh731801's Avatar
yh731801
(% F-150 FI 302, what engine years are a bolt-in/ plug in replacement? I'm an old time rodder built my 69 ford from ground up, but don't know doo-doo abuot these electronic computer controlled things
Old Jan 14, 2007 | 11:03 AM
Conanski's Avatar
Conanski
Pretty much any 302 shortblock will bolt in and function, thought the earlier heads(pre '75) were not all internally manifolded for air injection and there may be intake manifold bolt alignment issues. Specific power output varies wildly with year, but generally you can get as much as you want/need with mods.
Old Jan 14, 2007 | 01:14 PM
lostin90s's Avatar
lostin90s
What year is this for . If its our forum any thing from 88 to 97 should be about same cam wise ( for fuel injection) except 94 newer changed to 351 fire order.Cange order on dist. good luck
good to doo
Jan 25, 2015 12:37 AM
good to doo
Jan 3, 2015 05:43 PM
good to doo
Dec 15, 2014 03:19 PM
67fordtruck
Feb 22, 2014 03:04 PM
nagetech
Feb 20, 2014 06:27 PM
