Sponsored by: Real Truck
wiring harness colors
Old Jan 14, 2007 | 06:59 AM
eysham's Avatar
eysham
for the 2007 F350 CC SB 6.0 PSD
Is there a list of the wires/colours/function in the electric harnesses somwhere??
or better yet, a schematics of the electric stuff.
I installed an alarm/tracking system and they made a spaghetti mess.
now i need to figure out what is new and what was original...
eysham
Old Jan 14, 2007 | 05:02 PM
ReAX's Avatar
ReAX
I couldn't find 07, but this 06 should be close.
12volts yellow (30A), lt grn/pur (30A) +ignition harness
Starter dk. green + ignition harness
Ignition red/lt. green + ignition harness
Power Lock pink/yellow (w/o keyless) 5wi driver kick, door harness
Power Unlock pink/lt. green (w/o keyless) 5wi driver kick, door harness
Lock Motor pink/black 5wi driver kick or VSM, gray plug, pin 1
Unlock Motor red/orange 5wi driver kick or VSM, gray plug, pin 7
Disarm Defeat pink/orange 5wi pass. kick or VSM, gray plug, pin 8
Parking Lights+ brown + switch or VSM, green plug, pin 2
Hazards same as turn signal wires
Turn Signal(L) lt grn/wht (F), lt grn/org (R) + turn signal switch
Turn Signal(R) wht/lt blu (F), org/lt blu (R) + turn signal switch
Door Trigger use dome supervision wire
Dome Supervision black/lt. blue + pass kick or cluster, blu plg, pin26
Tachometer NOT red/lt green or red/yellow ac any ignition coil or fuel injector
Horn Trigger dk. blue - switch or VSM, green plug, pin 6
Old Jan 14, 2007 | 06:13 PM
PHWLEE's Avatar
PHWLEE
ReAX, good posting. I sure hope that was "copy/paste"
Old Jan 14, 2007 | 06:14 PM
ReAX's Avatar
ReAX
It was. You have to love the internet.
