Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Weekend Accomplishments
Old Jan 14, 2007 | 03:31 PM
Fomoko1's Avatar
Fomoko1
I probably asked you this before but is there no way of putting in an oil dipstick heater or a heater in the oil drain plug?
FGI has no solutions to offer? Surely there must be a way rather than getting rid of it and getting a Bobcat with a Kabota or an Isuzu.
Or maybe.......
Swap in the 390!!!!!
Old Jan 14, 2007 | 04:39 PM
51dueller's Avatar
51dueller
How about one of those magnetic heaters. We always stuck one on the auger motors to get them to start in the winter.
Old Jan 14, 2007 | 05:06 PM
LaredoF350's Avatar
LaredoF350
We also use some of those magnetic type. Most of the big truck places will have a pan plug element that screws into one of the drain plugs. Quite a few of our semis have had these.
Old Jan 14, 2007 | 05:16 PM
Fomoko1's Avatar
Fomoko1
I remember Glen saying there wasn`t any room at all under neath the motor, that`s why the dip stick heater idea.
Old Jan 14, 2007 | 06:04 PM
FirstTry's Avatar
FirstTry
Yeah, i didnt think i would be able to braze it, oh well, the JB weld should hold up.......i hope, i mean, if it can hold an engine together why not a belt buckle?
Old Jan 14, 2007 | 08:16 PM
Corner Gas's Avatar
Corner Gas
Worked the booth in the rink on Saturday, we were very very busy. Went through 8 boxes of burgers, 2 boxes of Chicken wings, 150lbs of potatos and what not. Today Amy and I went to the gun show.
Old Jan 14, 2007 | 09:04 PM
66gpw's Avatar
66gpw
Yes there is not enough room for the pan heater to be properly put on. I have tried with two heaters. One shorted out and the second one will not stay on tight enough. These are the flat ones that bolt to your oil pan bolts on the side of the ebgine block. My Bobcat has no place to do this on. So for now space heaters under a tarp in the quonset. I look forward to the day I finally get the shop heated. Other things have to be done first in there.
Old Jan 14, 2007 | 11:34 PM
Fomoko1's Avatar
Fomoko1
No way to use one or two heat lamps in the bottom of the engine compartment with some insulation around the top of the motor? It wouldn`t take much heat but I don`t think heat tape wouldn`t get warm enough.
There has to be a way to warm the motor up without having to heat the whole building.
Old Jan 15, 2007 | 12:28 AM
LaredoF350's Avatar
LaredoF350
Somehow, hoard it in and use any kind of heat source. We have an old parachute that we sometimes use to rescue things. On some of our trucks, we use old swather canvas standing up. Start from about drivers door around front and over to passenger door. We have a kerosene fired heater that we will use, placing it underneath and blowing forward.
Old Jan 15, 2007 | 06:58 AM
51dueller's Avatar
51dueller
I wonder if you could tie a battery warmer to the oil pan? They are only like 5/8 thick.
Old Jan 15, 2007 | 09:31 PM
66gpw's Avatar
66gpw
I have some bats of insulation. I can put that over the top of thr engine to help keep more heat on the motor. I have met a construction contrator a few years back. He said they had 3 of the same machines and they got rid ofthem for the same reason. The machines just did not start in the cold unless in heated shops. He said they were just more of a pain when they needed them in the cold weather.
I warm weather they work good.
Old Jan 15, 2007 | 09:46 PM
Snowking's Avatar
Snowking
At PetroCare we had 2- 763's and a S185 seemed to start well.
Old Jan 15, 2007 | 09:58 PM
  #28
Fomoko1's Avatar
Fomoko1
The 763 and S185 have liquid cooled Kabota engines with good block heaters so away better when it comes to cold weather starting.
