HPOP is draining
Old Jan 13, 2007 | 06:22 PM
357fhp's Avatar
357fhp
Red face HPOP is draining
Hi All
It went down a pint over night.
Do you replace the spring or stretch it like we used to the oil pressure springs on the old 292 and 312's to increase the oil pressure.
Old Jan 13, 2007 | 06:35 PM
Uzumati's Avatar
Uzumati
The service manual list them as separate parts but doen't list any numbers for them.
3 — Anti-drain check ball cap (part of 6658)
4 — O-ring seal (part of 6658)
5 — Spring (part of 6658)
6 — Check ball (part of 6658)
If you stretch it and get it too stiff there is a chance the LPOP wont feed the HPOP on startup.
HPOPuring initial start or cold start, the high-pressure oil pump (6600) receives unfiltered oil from the left side valve lifter oil gallery through the anti-drain back check ball valve. Once the engine starts or during warm engine starts, the check ball closes and the high-pressure oil pump receives filtered oil from the high-pressure oil pump reservoir. The high-pressure oil pump pumps the oil under extremely high pressures (4,115-20,577 kPa [600-3,000 psi]) through the left and right side high-pressure supply hoses to the high-pressure oil rails (integral to the cylinder heads). Once in the oil rail, the oil is fed to the fuel injector bores through four oil feed galleries drilled and machined in the cylinder head. The high-pressure oil then actuates the fuel injectors.
Old Jan 13, 2007 | 08:23 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Originally Posted by 357fhp
Hi All
You could always try it. If the seal and remainder of the assembly look OK, the only thing it can hurt (I think) is not getting oil to the HPOP and the truck will die. Are you sure it is the spring and not the seal?
Old Jan 14, 2007 | 04:20 AM
Mach1's Avatar
Mach1
The kit is cheap from Ford, just replace all the components, I have installed one before.
