Largest spare?
Old Jan 13, 2007 | 11:47 AM
houlster's Avatar
houlster
Largest spare?
Anybody know the largest size spare that'll fit in the stock location on an '01 Expy? Would a 305 or 315/70 R17 fit under there? With or without the stock hitch or a different hitch?
--Dan
Old Jan 13, 2007 | 08:00 PM
High_Horse's Avatar
High_Horse
Go to a tire store Tire Kingdom or whomever, they'll measure your space available and measure tires to see what'll fit.
Example, a Desert Dueller may measure 22" OD (outer diameter) and a Uniroyal Cross Country may measure 21 1/2" for the same size rim, but have the same code.
Old Jan 15, 2007 | 09:46 AM
buzzard's Avatar
buzzard
I've got a 33" tire/wheel combo tucked up there with a receiver hitch.
Old Apr 23, 2007 | 09:50 PM
bubahyde's Avatar
bubahyde
315/70R17 WILL NOT FIT
At least not with the factory Hitch, and I dought there is any way with an Aftermaket hitch.
My truck is a 2001 4x4 eddie bauer (non air suspension)
I was thinking of trying to relocate my hitch out some, but I do tow from time to time, and I dont want to mess anything up with my hitch, so if I get a flat, I will have a mini spare, If you have an later Model Expy, You may notice there is not a 2wd option. If you should get a flat and have to use a smaller size tire from whats on the truck, you need to pull the fuse for the Transfer case so the truck doen't shift in to A4wd.
Old Apr 24, 2007 | 10:22 AM
RedWireUsA's Avatar
RedWireUsA
Hey,
I was in almost the same boat. I have 315x75x16 and my exhaust prevented proper storage. There are exterior holders that "Monsta" recommend this for me:
http://www.etrailer.com/pc-FMH~6715...&utm_medium=ppc
This one will set you back some coin! The Bonarue II is the ultimate spare tire carrier.
http://www.sparetirecarrier.com/
Another good option (& MUCH cheaper) is Ride-on tire sealant. www.ride-on.com
Hope it helps
RedWireUSA
__________________
Old Apr 24, 2007 | 10:29 AM
RedWireUsA's Avatar
RedWireUsA
Bump!
Sorry first link again!
http://www.etrailer.com/mm5/merchant...egory_Code=FMH
RedWireUSA
Rudiak
Dec 9, 2017 08:52 AM
jhogh91
Nov 27, 2015 03:04 AM
sgip2000
15
Apr 11, 2015 08:43 AM
bigpetie
May 28, 2014 04:24 AM
jcammarata
Apr 2, 2014 08:47 PM
