Competition Diesel racing, sleds, dynos, power tuning and max performance.
Coolingmist or Snow Performance??
Old 03-07-2007, 11:20 PM
6L PWR's Avatar
6L PWR
6L PWR is offline
I'm thinking of adding a Water/Meth injection system to help lower the EGT's a bit. Which one is the best?
Old 03-08-2007, 12:29 AM
phil6608's Avatar
phil6608
phil6608 is offline
I run a stage 2 Snow kit on my gas-er. I like it and It works great. Never had a problem with it.
Old 03-08-2007, 12:57 AM
Industrial_dude's Avatar
Industrial_dude
Industrial_dude is offline
I run the snow performance stage 2 kit and think its a waste of money. It cools down the temps but unless you install a huge tank for the waTER/methanol youll have to keep filling up the tank every half hour of towing. worthless to me atleast.
Old 03-08-2007, 01:17 AM
Industrial_dude
oh yea and since we are in the competition forum if you want it for racing id say go with a small shot of noz instead.
Old 03-08-2007, 09:29 PM
6L PWR's Avatar
6L PWR
6L PWR is offline
Check my sig and you'll see I've already got the NOS. 100HP shot actually. Since the Stage II's were installed, I've got TONS of smoke and EGT's get very high, very quick. Looking for this mostly for running at the strip.
Old 03-08-2007, 10:14 PM
Industrial_dude
I see it now.. so how is your tranny running so far with all that work done? does it puke coolant at all with your arps? what are you hitting on the 1/4 mile if you dont mind me asking?
Old 03-09-2007, 06:12 PM
6L PWR's Avatar
6L PWR
6L PWR is offline
No tranny problems at all. I do have an aftermarket Torque Converter as well.
It never did puke all that much coolant before. I started off at 2500 miles with an Edge Juice Platinum with Hot code and NOS. It ran a 13.8 like that.
Not only do I have the Studs, but I totally removed the EGR cooler and plugged it.
I haven't been to the track since my latest mods. Just finished them up in Dec. 06. Planning on hitting the track nexxt weekend. I have been up against a truck that consistently runs a 12.3 and I pulled away. Too freakin' kewel!! Dying for numbers!!
Old 03-10-2007, 09:32 PM
CSIPSD's Avatar
CSIPSD
CSIPSD is offline
I have the Snows kit... It has worked fine for 2 years but there coustmer service sucks, there support after the sale sucks, and they want a small fortune for there injectors... Get the cooling mist kit, I have installed theres and it is 99% better then the Snows... Just look at there (snows) stage 3 kit and then at the cooling mist...
Old 04-22-2007, 12:06 AM
tiredlr's Avatar
tiredlr
tiredlr is offline
I run a real basic single stage system from Coolingmist. The service and tech help from David are excellent. Since I put my kit on they have added braided steel lines and new couplers/fittings for the lines, and also a very versatile variable controller that you can use both boost and EGT's to run the water.
My 6 gallon tank and pump are mounted in my tool box. I can use all 6 gallons when towing my towhauler in about 100 miles. Wanting to go to atleast to a dual nozzle setup if not a dual stage set up.
I notice the EGT's are reduced by about 150 degrees or so. Its kind of neat to watch them actaully dropping(digital gauge), and you know when the waters on!
Old 05-01-2007, 05:06 PM
Firestarter116's Avatar
Firestarter116
Firestarter116 is offline
does either kit add much power? EGT'S not really a problem
Old 05-02-2007, 11:51 AM
CSIPSD's Avatar
CSIPSD
CSIPSD is offline
About 40-60hp at 40% meth... But If your EGT's are not an issue, then add more fuel!
bradphx
67
01-10-2024 06:12 PM
Aerostar
01-14-2015 03:16 AM
miko6810
Modular V10 (6.8l)
06-04-2014 06:14 AM
Oklahoma Chapter
04-11-2003 10:33 PM
walterdanek
16
02-16-2001 07:56 PM
Quick Reply: Coolingmist or Snow Performance??
