King Pin Bearing Orientation
Old Mar 31, 2000 | 09:17 PM
Earl's Avatar
Earl
I just replaced the kingpins on my '56 F-250 and I noted that the kingpin bearings have an open side and a closed side. The last person who serviced the vehicle put one bearing in with the open side up and one bearing in with the closed side up. I suspect that the closed side should be up to prevent water, dirt, etc. from collecting inside the bearing. I can't tell from the illustrations in the shop manual and it doesn't give the bearing orientation details in the service instructions. Anybody know which way the bearings go in?
Also, I need to put a couple of shims in each side to make up for 50 years of wear. I have the shims and I think they should go below the bearing, against the inside surface of the lower arm of the spindle. Anybody know if this is correct?
Thanks.
Old Apr 1, 2000 | 05:18 AM
Bobs60F100's Avatar
Bobs60F100
Earl,
Acording to my 60 manual the bearing opening faces up and the shims go on the top of the spindle. Hope this helps.
Bob Wood
Old Apr 1, 2000 | 01:44 PM
Earl's Avatar
Earl
Thanks, Bob. I checked a couple of later sources and they confirm your info. Glad I found out before I put the whole thing together! Thanks again.
Old Apr 2, 2000 | 10:19 AM
phordman's Avatar
phordman
farmerchad
2004 - 2008 F150
Feb 8, 2017 05:56 PM
jason8374
Apr 27, 2015 07:01 PM
straight-shot
Mar 4, 2014 10:27 PM
Andrew Tuning
Jul 23, 2012 04:06 AM
voodoosurfer
Oct 30, 2003 06:45 AM
