i have a 2000 v10 f250 cc 3.73 gears and am only geting 6.6 miles to the gallon no towing at a half a tank i only get 90 miles i know its a v 10 but what could the problem be new air cleaner installed already dealer said plugs were changed before i bought may not be reliable any help please
900rr also wrote this:
have a 2000 cc v10 f250 4x4 that when the truck is sitting and i am trying to turn the wheel it will not budge the dealer replaced the power steering pump and it still did not help it is full of fluid checked that first. the mechanic said that it was normal because of the trucks weight . but with a truck that needs a empty parking lot to turn into or out of a spot it can be frustrating when you move it turns no problem if you stop to change direction the wheel will not move after that either any help please
i am glad that ever one is having fun with this post but what i have posted has all been true this is why i have posted here for some help i guess i need to look somewhere else for some advice by the way i have alwaysed had chevys and figured on trying a ford so far not so good hope it gets better
