Sponsored by: Real Truck
towing problem
Old Jan 12, 2007 | 04:23 PM
900rr's Avatar
900rr
towing problem
i bought a 2000 f 250 v10 cc 3.73 gears 4x4 and was towing today for first time. just bought truck a month ago anyways my problem is when going up a very small grade the truck will go from maybe 55 to if lucky 40 miles an hour no power what so ever trans does not shift rite away then when it does it revs really high not slipping high but high like 4000 rpms on this forum ever one talks about the v10 power and it didnot work overly well any help would be nice by the way i was only towing a four place snowmobile trailer enclosed with 4 snowmobiles in it. trailers a 21-24 footer tranny was just flushed when i bought it with a new air cleaner installed
Old Jan 12, 2007 | 05:08 PM
redford's Avatar
redford
FTE Leadership Emeritus
Could be a lot of things. See if you're truck is spitting any error codes.
My bet is a vacuum leak somewhere or a clogged catalytic converter.
Old Jan 12, 2007 | 05:31 PM
900rr's Avatar
900rr
truck seems to run and shift fine when empty so i think tranny is fine
Old Jan 12, 2007 | 05:48 PM
350steve's Avatar
350steve
You Try Towing Up Hill W/od Off?
Old Jan 12, 2007 | 05:53 PM
900rr's Avatar
900rr
o/d is off
Old Jan 12, 2007 | 05:56 PM
redford's Avatar
redford
OK, you have this truck, fuel mileage sucks and it doesn't seem to tow like you expected it to tow. You hit the hill t 55 and the trans kicked down and slowed to 40.
Your catalytic converter is clogged. Unhook your exhaust at the Y pipe and see if your truck doesn't run better. (It'll be loud).
Old Jan 12, 2007 | 06:11 PM
350steve's Avatar
350steve
Cruise Control On , O/d Off And Let The Trucks Computer Run Trany.it Will Run High Rpm. If Nothing Else Works Try A 6.0 W/4.30 Rears.
Old Jan 12, 2007 | 07:29 PM
900rr's Avatar
900rr
i just bought the truck still have not received the title yet so the selling or trading thing is not an option
Old Jan 12, 2007 | 07:44 PM
wcurtis's Avatar
wcurtis
Maybe be a fuel fitler, Less than $10 I would try it??? Good Luck
Old Jan 12, 2007 | 07:56 PM
900rr's Avatar
900rr
trying that tomorrow
Old Jan 12, 2007 | 08:07 PM
CyberJay's Avatar
CyberJay
I can't speak for the v10, but us 5.4 guys know that 4.10s(or 4.30s) make ALL the difference. The 5.4 straight up can't tow any significant weight with 3.73s IMO.
-Jay
Old Jan 12, 2007 | 10:06 PM
redford's Avatar
redford
Before you buy anything, unhook your exhaust at the Y pipe and take your truck out for a spin. It doesn't cost anything.
Old Jan 13, 2007 | 05:39 AM
LEVEL10's Avatar
LEVEL10
HELLO,
WE CAN HELP YOU WITH YOUR TOWING PROBLEMS. WE HAVE THE PARTS THAT YOU NEED TO BEEF UP YOU TRANS TO GET YOU MORE POWER TO THE WHEELS WHILE YOU ARE TOWING. THIS WILL ALSO GET YOUR HORSEPOWER TO THE WHEELS FASTER AND MORE EFFICIENTLY. CLICK ON THE LINK BELOW OR CALL FOR MORE INFORMATION.
MIKE
LEVEL 10 PRODUCTS
973-827-1000
http://www.levelten.com/
Old Jan 14, 2007 | 01:11 PM
900rr's Avatar
900rr
replaced the fuel filter and no help the exhaust doesn't seem to be the problem the tranny seems fine as well bacause even unloaded the truck going up a grade seems low on power .now looking on the posts what i am seeing is that these things like to rev my problem when loaded or unloaded is at the hill if i am doing 50- 40 the rpms are at about 1500-1700 on the tach. i know that the gears are 3.73 but what i need to know before i change these gears is how much of a diffenece will this change make any help at how well everbodys truck pulls with different gears and at what rpm and speed would be great thanks everyone for the help and advice so far
Old Jan 14, 2007 | 02:27 PM
350steve's Avatar
350steve
If Your Thinking About Changing Gears The $$ Spent You Will Not Recover, With The Problems You Have W/mpg. Think About A Programer.i Run A F350 W/4.30 460 Dual Tanks ,you Can Watch The Fuel Gauge Go Down, Another REASON I Got A Diesel.look Into A Tuner.W/LARGER GEARS LESS MPG
