Miss at Idle when warm
Old Jan 12, 2007 | 01:29 PM
STACK86's Avatar
STACK86
Cool Miss at Idle when warm
After rerouting plug wires the high speed miss I had is gone. Now I have a miss at idle only after the engine gets warm. Engine rpm drops and idle gets rough then recovers, occurs about every 3-4 seconds. 1986 F-150 with 302 and AOD.
I have changed the fuel filter.
Any suggestions appreciated.
Thanks,
Old Jan 12, 2007 | 02:16 PM
willys59cj5's Avatar
willys59cj5
Sounds exactly like the problem I am having. If you figure it out let me know what the solution was. I'll let you know if I find anything out.
Old Jan 14, 2007 | 04:47 PM
cb1525's Avatar
cb1525
I've had the same problem with 3 fords a 85 a 76 and a 75 two 460s and 1 390. The ground cable that grounds the engin to the fire wall. I'm not saing this will fix your problem but it is one of the last thing you think of.
Old Jan 15, 2007 | 03:52 PM
84f250460's Avatar
84f250460
im also having the same problem. ill have to try the ground.
Old Jan 15, 2007 | 10:28 PM
84f250460's Avatar
84f250460
well it seems the ground was the prob w/ mine idles smooth now.
big-head
Aug 3, 2015 10:20 PM
Tmaxx35
Jan 4, 2015 10:38 AM
bigcountry25
2004 - 2008 F150
Aug 21, 2014 09:46 AM
DBANDGB
Jul 15, 2014 04:46 PM
sibcc
Dec 9, 2010 04:37 PM
