B-series, Leaning Hard
Old Jan 12, 2007 | 11:25 AM
hedhntr's Avatar
hedhntr
91 B2600I leaning real hard to the passenger side, about a inch and a half. Could this be a simple shock replacement or a front end job thanks
Old Jan 12, 2007 | 08:50 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
I'm not real familiar with the older "REAL" mazda trucks but I'll try to help.
First off, shocks will in NO way affect ride height, so it's not them.
If you have torsion bars, make sure the adjustment bolts have not backed out.
Take a close look at the springs and make sure none are broken.... run your hands over the entire coil assembly, as they can break sometimes near the bottom or top of the spring and you won't necessarily be able to tell visually.
Check the ball joints and control arm bushings for play, as this can affect ride height sometimes.
Given the age and the design of the vehicle, I'd be willing to bet it's most likely a sagging spring somewhere.
Good luck!
toad84
Sep 6, 2021 01:34 PM
Octane
1997 - 2003 F150
17
Oct 6, 2017 10:32 AM
tbolt64
Jan 25, 2013 11:02 AM
fordcountry250
Feb 15, 2009 08:24 PM
Braker 19
1997 - 2003 F150
May 1, 2007 10:34 AM
