52'F3,Carburator
Old Apr 23, 2000 | 08:45 PM
Jed's Avatar
Jed
52'F3,Carburator
Having carb problem. Truck starts up ok when the engine temp reachs approx. 100degrees the motor stalls.Cools down and you can start it back up, reachs 100degrees and dies. Orginal V8 and carb. Fuel lines are good,filter good,jets working, float is good.HELP
Old Apr 23, 2000 | 11:01 PM
Bobs60F100's Avatar
Bobs60F100
52'F3,Carburator
sounds like vapor lock. Which means the carb is getting hot and evaporatinng the fuel. It is usually caused by a bad carb insulator or pluged water passeges in the manifold. A real easy check is to fill a couple of zip locks half full of ice water and put them around the base of the carb. If it runs longer you are having vapor lock. This was also a old drag racer trick to get more horsepower. The ice water will cool the air charge resulting in a better fuel/air mix. It could also be a pluged fuel filter but I don't think so since it is temp related and not run time related. The carb insulator on these old trucks was made up of about 6 carb gaskets stapled or glued together. Modern engines usually use a aluminum spacer.
Bob Wood
Old Apr 24, 2000 | 05:43 AM
Flathead52's Avatar
Flathead52
52'F3,Carburator
Jed
Since the truck dies. I think it's not a carb problem, Now if after you shut it off it wouldn't start I would think it was vapor lock. I think you might want to look at the condenser and the coil. I've had this same problem and it was a bad condenser
Old Apr 24, 2000 | 06:17 AM
Jed's Avatar
Jed
52'F3,Carburator
Thanks for the reply I'll try the ice water trick today. Jed
Old Apr 24, 2000 | 02:04 PM
Babsman's Avatar
Babsman
52'F3,Carburator
