lifter question
Old Jan 11, 2007 | 03:45 PM
craigl58's Avatar
craigl58
lifter question
1976 390 Last summer I installed new cam and lifters everything went fine with a lot of help from you guys I have about 1500 miles on since I did the work. Today I get a loud lifter noise, pulled the valve cover, it's the #1 exhaust lifter first thing I noticed was a carbon like dirt around the hole in the intake where the pushrod goes through and there is play in the pushrod,I can move it up and down ever so slightly.Do you think it's just the lifter or is the cam wiped? Just thought I'd ask you guys before I start taking it apart. Thank you, Craig
Old Jan 15, 2007 | 02:07 PM
1975Ford's Avatar
1975Ford
I'm not sure how dirt would build up on the hole for pushrod on intake for the #1 exhaust.
Definetly post back with results.
Old Jan 15, 2007 | 03:05 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Well If it wasnt run very long with the Lifter like that ? When you get all the lifters out, take them apart and check to see if any crap has gotten in...wash them all out put them back together...Change your oil, and see where your at? What you might be thinking is carbon..Might be a part of a black umbrella seal (IF) that applies to what your running.. Mine are cut for PC seals..
RJ
Old Jan 15, 2007 | 11:49 PM
aMoneypit's Avatar
aMoneypit
Keep lifters in order for re assembly in the same location........aMP
craigibc
Jan 26, 2022 08:40 PM
timbersteel
Oct 16, 2014 11:57 PM
craigibc
Feb 5, 2010 06:50 AM
welavalle
Sep 17, 2006 02:30 AM
Cap'n Tea Bag
Sep 24, 2005 09:57 PM
