4x4 problem
Old Jan 11, 2007 | 01:46 PM
olthunter's Avatar
olthunter
4x4 problem
i was out in the snow today, and about every 2 minutes my driver side tire would pop out of 4x4 and it felt like i hit a huge pot hole. i turned around and make it back home so i'm hoping it's just a bad hub but was wondering what my problem could be and if any one has any input on what i should do? i have a 1980 f-150 ranger explorer. thanks
Old Jan 11, 2007 | 10:13 PM
f100beatertruck's Avatar
f100beatertruck
When you said it popped out of 4x4, did you have to stop and fix it? (ie re-lock the hub)
I've had old trucks with sized u-joints that when you first start using 4x4 they make some really cool sounds. They will also toss the steering wheel around if you're not going perfectly straight.
I would pop the hub off and take out the guts and inspect it. You could have striped splines, or it could be just a bad hub.
Go to the junk yard and get replacements. And spares too if you can...
lanceparker
Mar 23, 2008 09:55 PM
sdhillon1
2004 - 2008 F150
Jan 25, 2008 06:43 PM
DeezDay
British Columbia
Nov 18, 2007 10:26 AM
83f250460ci
Feb 16, 2003 02:29 PM
jsatt1
Oct 29, 2002 10:52 AM
