Sponsored by: Real Truck
Replacing Door Ajar Sensors
Old Jan 11, 2007 | 11:44 AM
J--Rod's Avatar
J--Rod
Thank you for all the replies on the stuck door sensors thread I started a week or two ago. Unfortunately the contact cleaner and WD-40 trick did not work for me....so I'm going in!
Anyone have experience with removing the door interior? Does it just unsnap? Seems pretty simple but I just don't want to break anything.
Old Jan 11, 2007 | 11:53 AM
redford's Avatar
redford
FTE Leadership Emeritus
Follow this:
http://www.eurekaboy.com/f250/doorremove.htm
Old Jan 11, 2007 | 12:01 PM
J--Rod's Avatar
J--Rod
Sweet!
That rocks! Thank you.
Old Jan 12, 2007 | 07:36 AM
BigGreen'77's Avatar
BigGreen'77
Yes, and whatever you do, dont forget after you get it loose and get everything unattatched, DO NOT pull out on it, lift UP on it.
Old Jan 12, 2007 | 09:04 AM
JFH's Avatar
JFH
I couldn't find your other post but wondering if you are referring to the door ajar ring not shutting off........if so(if not, disregard my post ), you may want to check your ignition key switch before you go digging. While the door is open, try jiggling the switch to see if the ringing stops. This is the case with mine........haven't had a channce to replace, but a least I know I can stop the ringing if I have to keep the door open.
Old Jan 12, 2007 | 09:22 AM
J--Rod's Avatar
J--Rod
Negative.
The problem is, when I drive, the door ajar light, and the dome lights/cargo light remains on.
Although, last night is seems to have temporarily fixed itself.
Old Jan 12, 2007 | 09:25 AM
savage2211's Avatar
savage2211
maybe the WD-40 worked its way into the right place...Cool .....
Old Jan 12, 2007 | 09:31 AM
redford's Avatar
redford
WD-40 and duct tape...all you need to fix anything.
If it doesn't move and it should - WD-40.
If it moves and it shouldn't - duct tape.
Old Jan 12, 2007 | 09:32 AM
J--Rod's Avatar
J--Rod
Very cool. I hope it lasts a while.
Old Jan 12, 2007 | 09:34 AM
savage2211's Avatar
savage2211
I have to spray mine about ounce a year..
Old Jan 12, 2007 | 09:39 AM
J--Rod's Avatar
J--Rod
Yeah, I'l probably do some preventitive spraying soon.
Old Jan 12, 2007 | 07:20 PM
ken kenmnedy's Avatar
ken kenmnedy
w-d 40 ,duct tape ,a good hammer and a hand full of dirt!!!!!!
Old Jan 13, 2007 | 07:08 PM
Jzinkiewicz's Avatar
Jzinkiewicz
I have the same problem, wd40 didn't work. Any luck????
Old Jan 13, 2007 | 08:07 PM
redford's Avatar
redford
It didn't work for J-rod at first. Keep spraying and praying.
