Engine missing when at cruising speed?
Old Jan 10, 2007 | 11:52 PM
akviggy's Avatar
akviggy
I have been searching these threads for hours trying to pin down an answer as to why my truck "misses" (coughs, sputters, hic-up) when at cruising speeds. It doesn't seem to matter if I'm cruising in 3rd gear, 4th gear, or OD. When I get on the throttle it picks right up, no problems. I can't get it to duplicate when not driving (ie: while parked, holding the throttle at different rpms) I have read it could be anything from a vacuum leak, my TPS, IAC, EGR, fuel pump, fuel filter, etc. I have replaced the, distributor, plugs, wires, and fuel filter. It seems this is a problem with a few I6's in this forum but I have yet to find one that fixed the problem. Please help.
Viggy
92 F150,x-cab, 4x4, 4.9L, 5sp.
Old Jan 11, 2007 | 11:19 AM
300I6VAN85's Avatar
300I6VAN85
Did you replace the distributor rotor cap? My 85 van would not start last week. I got it started and the only thing I think I did was to clean the contact post and rotor on the distributor with a pocket knife. I might have had a loose connection some where but I don't think so. It sound electrical to me. Check for bad grounds and connections. Look at the motor at night for sparks. Look at your dist cap again. Some times they can ark between the posts and it will score the cap.
Old Jan 11, 2007 | 11:30 AM
Harte3's Avatar
Harte3
I was experiencing a similar problem but at low to moderate speeds and light to moderate throttle pressure on my '83. The Tech's that are rebuilding my engine said the problem is common and that going down 1 or 2 sizes in the EGR metering usually eleminated the problem.
Old Jan 12, 2007 | 08:11 PM
akviggy's Avatar
akviggy
Harte3, that's exactly what my engine is doing. How do I decrease my EGR?
Old Jan 13, 2007 | 11:54 AM
Harte3's Avatar
Harte3
Apparently there are different sized metering parts that can go inside the EGR valve but that is all I can tell you about it. Check with an Emissions savy Tech and they can probably fill you in.
Also, I still had the problem after I had to have a new EGR valve installed to pass emissions but that was prior to talking to another Tech about the problem when he advised me about the different metering parts. In the mean time I had a Mallory HyFire 6a box installed along with a MSD Blaster 2 coil, opened the plug gap to 50 and that reduced the problem 90%+ and really woke it up.
BUT having said all that it appears you have a FI engine and mine is carbed ('83) and I am not at all familiar with the intricate workings of a FI engine.
WillaminaOR
1997 - 2003 F150
Sep 20, 2016 02:10 PM
mksnipe
Dec 15, 2015 08:22 AM
areyou4real
Aerostar
26
Nov 9, 2015 05:19 PM
Samsonitesamsonite
Mar 10, 2011 01:24 PM
Sedan300
Feb 25, 2010 04:49 PM
