92 5.0 pistons
Old Jan 10, 2007 | 10:56 PM
vega73gt's Avatar
vega73gt
92 5.0 pistons
Have any of you guy used these Sealed Power Coated Pistons http://cgi.ebay.com/ebaymotors/New-S...QQcmdZViewItem
I am going to rebuild 92 roller 5.0 to put in my 91. I am starting to buy the parts I need and seen these on ebay.Jim
Old Jan 10, 2007 | 11:00 PM
taisa899's Avatar
taisa899
they're what I used in my build and I haven't had any problems with them!
Jim
Old Jan 11, 2007 | 01:01 AM
KDPate's Avatar
KDPate
Sealed Power is good stuff. Mahle makes good pistons as well if you need an option.....
Old Jan 11, 2007 | 10:36 AM
vega73gt's Avatar
vega73gt
Some where I read that the coating comes off the pistons and then the slap the wall.
Jim
Old Jan 11, 2007 | 11:42 AM
HemiEater's Avatar
HemiEater
I don't think those are the right compression hiegth...I made the same mistake once, put one of the pistons in and it was like .020 down the hole so I would have lost all kinds of compression.
Old Jan 11, 2007 | 11:55 AM
HemiEater's Avatar
HemiEater
you need 1.619 compression hiegth to get the piston to 0 deck hiegth....
Old Jan 12, 2007 | 06:25 AM
desertdave35's Avatar
desertdave35
I used those in my rebuild as well. So far they are great, although I only have 500 miles on the rebuild so far. I got mine from Summit Racing for $79.12 and the part # was STL-H273CP20 ( mine were .020 over sized)
Old Jan 12, 2007 | 05:16 PM
baddad457's Avatar
baddad457
Yea, be warned, not all flat top 289/302/5.0 pistons have the correct pin height to achieve zero or near zero deck. Many have a 1.585 P/H leaving the piston top .020+ down the hole at TDC.
Old Jan 13, 2007 | 09:04 AM
AMDCAMARO's Avatar
AMDCAMARO
I stuck these inthe 350 i droped in my Camaro 2 years ago. Main reason I went with the coated skirts was to help with any piston slap I might get going to a .040 oversized piston. All it is is extra insurance for ya. If you are only doing a .020 over bore, regular un-coated speed-pro pistons should be fine.
