Bad Relay?
Old Jan 10, 2007 | 07:55 PM
Annie Dietrich's Avatar
Annie Dietrich
Smile Bad Relay?
Tried to start the truck and only got a click. Replaced batteries, but didn't solve the problem...only got a click. Engine will not turn over. HELP!! 1999 F250 Super Duty 7.3 Diesel
Old Jan 10, 2007 | 08:09 PM
Uzumati's Avatar
Uzumati
Check the starter solenoid behind the pass side battery next to the vacumn pump and then check all connections at the starter (make sure no corrosion there)
Old Jan 10, 2007 | 08:17 PM
powrstrkn''s Avatar
powrstrkn'
I would try crossing the solinoid in order to determine if that is the culprit.
Old Jan 10, 2007 | 08:34 PM
Annie Dietrich
My husband said he tried that...didn't work. Thanks!
Old Jan 10, 2007 | 08:44 PM
powrstrkn''s Avatar
powrstrkn'
Well, if the cable ends are clean, and crossing the solenoid didn't work I would either try to find another 7.3 psd to borrow one from to confirm a bad solenoid or replace it with a new one.
It sounds like the magnet isn't working.
Before you throw it out try tapping it with the handle of a screwdriver to see if the magnet can be unstuck.
Old Jan 10, 2007 | 08:45 PM
Smokin''s Avatar
Smokin'
Smokin
Any chances the CPS is the culprit here?
Old Jan 11, 2007 | 11:52 AM
Annie Dietrich
Good News...Bad News
Good News --- Problem found!
Bad News --- it's the starter. Lotsa $$$
Thank you for all your help!
Old Jan 11, 2007 | 10:10 PM
winn9524's Avatar
winn9524
I'm almost scared to ask, but what is a starter going to run a guy?
Any ideas of where to buy quality starters at?
