Considering the TSB requiring the nickel anti-seize compound, it stands to reason that the engine assembly process has been revised to include the anti-seize compound. Therefore there should be no problem with the plugs on the new engines. I would still put a wrench on each plug every 10,000 miles and slightly loosen, then re-snug it. Just to make sure. Do these engines have aluminum heads? The SOP for alloy heads has always been to never try to remove a hot plug. Of course the unusual extended 'snout' of these particular plugs is the problem, not the threads, and the TSB cautions against lubing the threads, which can cause over-tightening and stripped threads in the attempt to get the required torque (with aluminum cylinder heads).
I think I may do this in the spring on my 05, even though it will only have about 17K miles on it. I'm concerned about the length of time as well as the mileage, resulting in the plug threads siezing. How scary is this that a routine maintenance job can turn into a 4K cluster *$#% with on turn of a ratchet?
I think I will run mine to 100K and then trade it in on one that the manufacturer knows how to build an engine, checking or changing plugs every 30K on a truck that costs 40K give me a break!!!!!!!!!!!!!!
Am I to understand that there is not an aftermarket company that sells a spark plug for the F-150, Bosch, NGK etc....the 5.4 engine gets produced at approx. 1m units annually. It looks like someone is missing out on some moneymaking..
Anyway --an aftermarket plug could solve this problem if you can get your factory plugs out? Right?
Negative.
The only other plug manufacturer is Autolite, and those are made to the same spec as the Motorcraft.
That is one way to look at it... But what happens if your truck develops a miss and one or more of your plugs have to be pulled. At that point, you would have to ante up anyway. Just a thought...
FS-150, this is exactly the reasoning behind my decision. I had thought like Lineman that I would just unload the truck prior to 100K, but this engine running strong and without difficulty to 100K miles is not guaranteed at all. And having to change a plug out at 90K miles after reading this warning is not something I would look forward to doing at all. I think I'll take my chances this spring.
the plugs don't get worn out, they build up carbon deposits around the "bullet" of the plug and are hard to remove. my plugs have been removed and cleaned (following the tsb) at 40k and replaced at 80k cleaning the plug holes with something to break up the carbon such as seafoam deep-creep. no problems so far.
You are exactly right that is why I got the extended warranty if it starts missing then ford fixes it for sure probably will not let the extended warranty run out on this truck first time I ever bought a extra warranty on anything may pay off this time???????????
I'm assuming none of yours broke. Did you do it yourself or take it somewhere? How did they look at 40K? That's how many I have on my 05 and debating on replacing them now or waiting.
none broke and I did it myself. the back 2 on the passengers side are a little hard to get to. just follow the tsb on the plug removal, its very specific. you should be able to clean & replace the same plugs at 40k unless you just want new ones. these plugs are very expensive (about $20 each). as far as penetrating oil I like the sea foam. it'll break up the carbon deposits as well as lubricate. a little headache to save you a big headache.
Just did my plugs yesterday. I had taken them out and cleaned them about 400 miles ago thinking that it was the threads locking up so I just antiseized the threads, 2 pages later you guys got the info it was the ground shield seizing not the threads so instead of pulling and re-doing it I replaced them all with the autolites at $10.00 bucks a piece plus I used the motorcraft nickel anti-seize.In 400 miles those plugs were already carbed up again and I completely cleaned the shields when I had them out before. Way more carb build up going on then I would consider normal. And that motorcraft anti-seize is some thick gooey stuff.Good luck to everyone who braves this challenge.Oh by the way mines an 05 Lariat 2wd with 27k on it.
