Brazing joints together - (metal, that is!)
I am trying to finish the gas welding part of the welding article and have managed to confuse myself when it comes to brazing. I know most, if not all, of you don't do it, and have good reasons for not doing so. I just don't remember why!
I know:
1. easiest of all welds to make (little skill)
2. lap joint as strong as the material joined
3. low heat (less distortion)
4. very quick to set up and do.
5. no splatter.
Cons:
1. butt weld not very strong
2. requires clean joint
3. not good for filling voids
4. left-over flux can lift paint and filler if not carefully cleaned after welding.
Can you guys help me? Tell me why brazing is not such a good idea?
btw, see http://www.handyharmancanada.com/The...k/contents.htm for an idea of the good parts of brazing.
I know:
5. no splatter.
Cons:
I know:
5. no splatter.
Cons:
I know:
5. no splatter.
Cons:
What are you wanting to braze?
If I remember right
I know:
5. no splatter.
Cons:
btw, see http://www.handyharmancanada.com/TheBrazingBook/contents.htm for an idea of the good parts of brazing.
I know:
5. no splatter.
Cons:
I braze a part if it is thin metal that I know I blow through with the mig. I reinforced the front corner holes on my hoods by brazing a flat washer to the top side of the lip, you don't see it from the bottom looking up. These are the holes in the front of the'48-50 hoods that like to crack and travel up the sid of the hood. Anyone with one of these trucks knows the area I am talking about.
I'm no expert for sure, but: You don't use brazing for butt welds, only for joints with large surfaces in contact with each other (lap welds). Also, although the temps are lower, they are applied over a larger area, so I don't agree with the "less distortion" in all cases. Another "con" is that if you try brazing and it doesn't hold, you'll never be able to weld it because the copper spoils the metal for welding.
Technically brazing is hot joining using a lower melting temp filler rod that forms a bond at the interface by creating a new alloy at the juncture a few molecules deep. The filler alloy bridges between the two pieces being joined, there is no actual joining of the two pieces directly to each other, so it can be separated again with a second application of heat to the joint. That's why brazing a but joint is not very sucessful, too little surface area at the joint and the bridging metal is often somewhat brittle. The problem with brazing in bodywork is that the joining alloy for steel is a brass alloy, and paint does not stick very well to brass. There would be a lot of people who polish brass that would be eternally grateful to anyone who formulates a clear coating for brass that won't eventually chip and peel off. brazing is fine for a low stress overlapping joint that doesn't need to be painted. I prefer using high tensile nickle "silver" rod for brazing steel over yellow brass rod.
