Sponsored by: Real Truck
Help! Doors stuck shut
Old Jan 10, 2007 | 12:12 PM
Pony Power's Avatar
Pony Power
Cool Help! Doors stuck shut
Every time it snows or rains and freezes my doors are a real b---- to get open!
Is there a weatherstrip dressing that will keep this from being an every day occurrence.
Old Jan 10, 2007 | 12:28 PM
Ace!'s Avatar
Ace!
Yeah, happened to me a day or so ago. I was able to open one of the passenger doors pretty easy got the thing started and let it warm up a bit.
A co-worker of mine broke a door handle pulling too hard.
Old Jan 10, 2007 | 12:42 PM
USMC Diesel's Avatar
USMC Diesel
Use a light coat of grease on the locking mechanism to help repel the water
Old Jan 10, 2007 | 12:54 PM
Pony Power's Avatar
Pony Power
Its not the locks that are freezing, the whole weatherstrip around the top of the doors freezes from the water laying up there.
I just called Ford and the parts man said they don't sell any product for that but silicone spray will fix it. I did a Google search and GM makes a silicone grease stick that you rub on. Looks pretty good but the article said its expensive and didn't give the price.
Old Jan 10, 2007 | 02:50 PM
redford's Avatar
redford
FTE Leadership Emeritus
You can get silicon spray at any decent parts store like Autozone.
Old Jan 10, 2007 | 04:19 PM
toozak's Avatar
toozak
I live in the Northeast and have had the same issue on vehicles and have had good luck with the silicone spray on they weatherstrip. Any auto parts place or good hardware store should have it.
Old Jan 10, 2007 | 04:27 PM
Mr Incredible's Avatar
Mr Incredible
I suggest using silicone spray or wipe on the rubber and the door itself.
Also, a little tip. On my '99, while I work the latch I reach down to the bottom of the door and pull on the lip that's there. That gets it open every time.
Don't know about other years having that lip. Anybody?
Old Jan 10, 2007 | 05:02 PM
jim henderson's Avatar
jim henderson
When I used to live in the Frozen wasteland, I used a silicone grease that was made for weatherstripping. It came in a "toothpaste tube". Worked pretty good. Most parts stores will know what you want. Now that I live in sunny SoCal I have no clue what I will do with the silicone grease, sure ain't gonna freeze up on me here.
Won't help if ice seals over the seam of the sheet metal.
Good Luck,
Jim Henderson
Old Jan 10, 2007 | 05:22 PM
PHWLEE's Avatar
PHWLEE
Originally Posted by jim henderson
....Now that I live in sunny SoCal I have no clue what I will do with the silicone grease, sure ain't gonna freeze up on me here......
Jim Henderson
You can send that tub of silicone up here to the Northeast. We need it here and the temps are dropping!
Old Jan 10, 2007 | 07:43 PM
edjunior's Avatar
edjunior
Move south!! Cold weather sucks!!
Old Jan 10, 2007 | 09:37 PM
arctic y block's Avatar
arctic y block
It's 12 to 16F here. We leave the door on the first latch. It ain't raining or snowing. Just clear and getting colder. What you guy up around Anchorage and Fairbanks doing about it.
Old Jan 11, 2007 | 12:56 PM
Pony Power's Avatar
Pony Power
Update: Well we had another 2" of snow last evening and then a hard freeze down to 20 degrees.
Yesterday afternoon I applied some silicone spray to the weather strips and door locks. It sorta worked. I got one out of four doors to open freely.
The main problem is that water lays on the top area of the door and then freezes. I did find a easy way to open them, I used a mini pry bar, screwdriver sized, wrapped in cloth and stuck it in right by the top corner of the door while pulling on the door latch and they opened with hardly using any pressure. Not enough pressure to chip the paint.
Conclusion: I think the silicone grease is probably the best way to go.
Old Jan 11, 2007 | 01:11 PM
Powermoon's Avatar
Powermoon
Pony Power, where are you located in WA. I'm also in WA, no snow right now but supposed to get down in singal digits tonight where I'm at.
Old Jan 11, 2007 | 01:17 PM
CARV's Avatar
CARV
I use Vaseline. Rub it into the weather strip just as you would rub hand cream into your hand. Has always worked for me!
Old Jan 11, 2007 | 09:43 PM
Pony Power's Avatar
Pony Power
Powermoon, I'm 200 west of you in Silverdale. Its near Bremerton on the Kitsap Peninsula. I got a tube of Silicone grease from our local parts house today for a little over $10 and applied that to the stripping. Should be good to go now, the parts guy said he uses that stuff and it works well for him.
I thought about using petroleum jelly on it but that stuff isn't good for rubber based products, and as long as I keep my stuff I didn't want to chance it.
