1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
PATS bypass trick?
Old 01-12-2007, 11:50 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Originally Posted by kslhol
When I get my spares set up, I am going to try your PATS antenna loop trick. I am going to install a remote starter and I would like to save the price of a PATS bypass modular. $25 bucks is $25 bucks. Plus the extra time wiring it.
Takes all of 5 extra minutes to wire up the bypass module. +12volts and the negative connects to the alarm module.
Old 01-12-2007, 11:58 PM
kslhol's Avatar
kslhol
kslhol is offline
Oh... I guess I assumed the bypass would be more of a pain than the actual remote starter would be. Thanks for the info.
Old 01-13-2007, 12:06 AM
MisterCMK's Avatar
MisterCMK
Nope, the ford bypass is 2 wires plus the antenna ring that slips around the lock cylinder. Its a pretty easy install.
Old 07-11-2012, 10:25 PM
maverick1701's Avatar
maverick1701
maverick1701 is offline
subscribing so I can do this trick!
Old 03-10-2017, 07:14 PM
Red Mauldin's Avatar
Red Mauldin
Red Mauldin is offline
How hard is it to get to the antenna loop. Does the plastic around the lock cylinder have to be removed and if so, how do you get it off without breaking anything or cracking the plastic.
Everything just clicks and snaps off in my dodge but the trim in the interior of the Expedition seems locked in tight. Are there some screws or something I am not seeing...
and where exactly did you buy the modular? I just got off the phone with a Ford dealer and the price you give and the price they gave is a very big difference.
Old 03-10-2017, 07:57 PM
lv2race's Avatar
lv2race
lv2race is offline
That was Jan 2007....
Alot can happen in 10 years.
Old 03-11-2017, 09:39 AM
alloro's Avatar
alloro
alloro is offline
Received 4,242 Likes on 2,473 Posts
The price for what exactly?
Old 06-17-2017, 05:03 PM
Melanni Garcia's Avatar
Melanni Garcia
Melanni Garcia is offline
I know its been awhile since this was posted, but you wouldn't happen to have a picture, would you? I'm having a really hard time with my 98 mustang and the ignition/pats system. It was rewired by the po and I'm at a loss. It was somewhat bypassed with push button start and a little chip hanging inside the black ring around the lock cylinder. A couple weeks ago my son drove to store and back, key wouldn't come out, had to disconnect battery. But the car would still start with push button start. Went to work on it today hoping it was the park neutral safety switch or something easy preventing me from turning off key, but now the theft light is on and it won't start. Don't have any chip keys, none came with it and it worked fine for the past few months.
Old 06-17-2017, 06:55 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,634 Likes on 1,097 Posts
Originally Posted by Torque1st
I refused to pay several hundred for a new key to be programmed.
I bought a car with PATS. The guy I bought it from only had one key. A local locksmith cut a new PATS key and programmed it. I paid him $45.
Old 06-17-2017, 07:00 PM
Melanni Garcia
Did he the first key to program the duplicates? Because I don't have a chip key at all. It was starting with a 2 dollar Wal-Mart copy for the last 3 months.
Old 06-17-2017, 08:14 PM
Mark Kovalsky
If it is starting without a chipped key either someone hid a chip near the ignition switch or it doesn't have PATS.
Old 06-17-2017, 09:00 PM
Melanni Garcia
I know there's a little wire with a metal tab that hangs in the black ring around the lock cylinder and it was rewired with a push button start.
Tylus
2004 - 2008 F150
74
10-25-2019 02:18 AM
BearMan54
1983 - 2012 Ranger & B-Series
33
02-13-2018 03:46 PM
rjent
1997 - 2003 F150
24
07-18-2017 06:19 AM
hellssorrow
1997 - 2003 F150
09-04-2016 10:42 PM
Psyclopse
03-14-2016 10:29 AM
Quick Reply: PATS bypass trick?
