The sputtering won't quit
Old Jan 10, 2007 | 06:20 AM
1988F1504x2's Avatar
1988F1504x2
My 88 F-150 won't quit sputtering. It sputters like it wants to die at lower RPM's, esp. under load. The thing will stutter until 2000RPM's or so. I have given it new plugs(autolite, all tested good w/ ohmmeter), new Autolite Pro wires, new cap and rotor, new alternator, new Idle air switch, new Throttle Position sensor. The exhaust had been cut-off, but now has a 3' length of pipe running to 31" glasspack and that's it.
Old Jan 10, 2007 | 07:58 AM
Conanski's Avatar
Conanski
Ignition coil or ignition module(on the distributor) I bet. Check codes first.
