1991 F150 Custom Problem
Old Mar 7, 2008 | 11:48 PM
ben10's Avatar
ben10
I will check it out it acts up at the same time every time when it hits normal running temp when i hit between 55 and 65 and when i put it in 5TH all three things happen at about the same time one more thing it smokes now sometimes a lot other times not much at all
Old Mar 8, 2008 | 12:06 AM
Noneshere's Avatar
Noneshere
Probably just running rich.....cause of the EGR position
Well the smoke could be valve seals, worn piston rings, or even a small leak in the head gasket developing.
More then likely valve seals if any of the above (common with high mileage).
White smoke would be water, and black is oil or a rich fuel mixture.
The EGR valve may be incorrectly opening more. and the fuel is not compensating correctly or quickly enough, making too rich of a mixture and blowing it out .
You should be able to smell the slight differences.
Pull your plugs , they should tell you whats happening at "ground zero".
The deposits will be built up on the gap.
Black is rich (oil / Fuel) , white is lean (oxygenation), yellow is a lean glazing of the richer substances.
Old Mar 10, 2008 | 04:14 PM
dopeys4x4's Avatar
dopeys4x4
did u get it yet
Old Mar 11, 2008 | 08:48 AM
jas88's Avatar
jas88
I think those 2 are not related. These trucks eat EVP sensors regularly.
My bet on this one is the pickup coil in the distributor. Either that or the ignition coil but the pickup coil is a more common failure on this kind of symptom.
cbmule
Feb 11, 2014 05:05 PM
Ecarlton1991
Aug 28, 2011 01:44 PM
loseboltssinkships
Jan 5, 2011 09:53 AM
jmsjmsjms
Aug 2, 2009 03:25 PM
gaffmedic
Aug 13, 2007 06:48 PM
