Would it be wise to convert now?
Old Jan 9, 2007 | 05:02 PM
ech0sh4y's Avatar
ech0sh4y
Hey fellas -
I have a 96 f250 psd srt cab lng bed....
anyways I just recently checked out the front end of this thing and i come to find out that it needs pretty much everything... ball joints, tie rods, rotors, i think one caliper is frozen, and more....
My question is... should i waste all this money and replace it all or should i just convert to a soild axel now? I planned on doing it sometime later and I plan on lifting it hopefully. I head that the 99+ soild axles will swap in... and insight or opinions would be greatly appreciated! Thanks!!
Brian
Old Jan 9, 2007 | 05:09 PM
handyman43358's Avatar
handyman43358
I'd think a solid axle from 92-97 would work. They're all Dana 60's. You have the Dana 50 now correct?
Old Jan 9, 2007 | 05:11 PM
ech0sh4y's Avatar
ech0sh4y
I believe so ... only f350s came with soild axles is that what your talking about? wouldn't i have to worry about bolt patterns or something then?
Old Jan 9, 2007 | 06:17 PM
lostin90s's Avatar
lostin90s
No there are no bolt difference on 97 down single wheel F350 . As for the newer axle I thought they did change bolt pattern . but all trucks I run are duelly and rims are different. good luck
Old Jan 9, 2007 | 06:19 PM
ech0sh4y's Avatar
ech0sh4y
awsome now the hunt is on for a dana 60 ... what are the kingpin axles? Thanks guys for your info.
Old Jan 9, 2007 | 08:41 PM
ech0sh4y's Avatar
ech0sh4y
Any good place to try looking for them? Has anyone done this before?
Old Jan 9, 2007 | 08:55 PM
alxsnmr's Avatar
alxsnmr
The swap should be straight forward to the point that it is a direct bolt in. The newer body style superdutys use a metric pattern for the bolt pattern and also are hub centered and not bolt centered. I also recall ford used a locating rod/trackbar on the front axle at some point on the leaf sprung solid fronts.
Old Jan 9, 2007 | 09:06 PM
ech0sh4y's Avatar
ech0sh4y
will my leafs work or do i need to get those with the axle? I plan on getting a 86-96 axle this shoudl be the same bolt right?
danger-ranger93
105
Jan 19, 2011 02:43 PM
joewaldner
Offroad & 4x4
Sep 14, 2008 10:24 PM
F350JOHN
Offroad & 4x4
21
Jul 29, 2008 09:32 PM
thegreenmachine
Offroad & 4x4
Nov 13, 2005 07:51 PM
Danos-f150
Mar 25, 2005 12:36 AM
