Sponsored by: Auxito
Need Help
Old Jan 9, 2007 | 10:55 AM
DenverAngl's Avatar
DenverAngl
Question Need Help
The Battery light came on in my truck it will start even after sitting all night is idoling really high
Old Jan 9, 2007 | 12:41 PM
FTE Ken's Avatar
FTE Ken
Moved to the 1997-2003 F150 section.
Old Jan 9, 2007 | 01:44 PM
KingRanchMan02's Avatar
KingRanchMan02
Hello Denver and welcome to FTE!
If I am not mistaken, the battery light being illuminated indicates a charging problem. This is like the alternator light in older vehicles. It may be starting now but pretty soon it may not. The high idle could be a IAC or TPS problem. Take it and have the alternator checked out. Good luck.
Old Jan 10, 2007 | 10:52 AM
FordMan03's Avatar
FordMan03
Just start it and pull the postive off the battery. If it shuts off, this tells you your truck is running off the battery and the alternator is bad.
Old Jan 10, 2007 | 11:26 AM
KingRanchMan02
Not the best advice. The battery provides a filtering effect on the electrical system. Removing the battery from the alternator will unload the system and can have very detrimental effects on electronic devices in the truck.
Old Jan 10, 2007 | 06:25 PM
searay220's Avatar
searay220
Boy that's the truth! You NEVER want to remove the battery cable while a vehicle is running. This was a common practice BEFORE computer controlled engines to see if the alternator was working. Try that on a newer auto and you will fry the CPU. Take the truck to Auto Zone and they will check the battery/charging system for free.
Old Jan 11, 2007 | 07:07 AM
FordMan03's Avatar
FordMan03
Sorry for the bad advice. I guess I'm just old school. Thanks for straightening that out fellas before I caused somebody to damage their truck including me.
Old Jan 12, 2007 | 02:18 AM
Gumbyagain's Avatar
Gumbyagain
Indeed! Modern Alternators monitor battery voltage & need the 12 volt input to operate properly. Any Autozone, Oreily's, Advanced or other chains will test your charging system for free because they hope to sell you the parts to fix it. If your not capable of replacing parts Then chains like PepBoys will do installs & Those like AZ & ADV will normally have a local shop or 2 they recommend.
Old Jan 12, 2007 | 02:52 AM
LxMan1's Avatar
LxMan1
Sounds like it's not charging to me. Better get it tested before you get stranded.
