Sponsored by: Kumho
Problem Removing Rear Brake Rotors
Old Jan 9, 2007 | 09:41 AM
capewave's Avatar
capewave
I have a 2001 Mountaineer AWD and I went to replace the rear brakes first time on this truck. I removed the calipers changed the pads and went to take rotor off and replace and could not get it to budge. I took a 3lb hameer and tried to loosen up and it did a little but will not come off. All the rotors I have replaced before generally come right off. Same with the other side. The rotors that are on there were not scored or warped so I replaced the calipers and everything is fine. But I would like to replace the rotors since I have them. Any suggestions would be great.
Thanks
Capewave
Old Jan 9, 2007 | 01:51 PM
cujo8's Avatar
cujo8
I am not sure what your setup looks like, but I recently did two rear break jobs on a couple of GM vehicles and I found they tend to get stuck on the hub ring. I usually try and wire brush the area as good as I can and then spray some penetrating oil around the hub. I then rotate the rotor and hit it with a 5lb hammer on the back edge from where the calipers were mounted, at least for cars I worked on this worked. When you get them off clean the hub good with the wire brush and then put some anti-sieze around the hub mating surface and this will not happen again.
