1978 - 1996 Big Bronco
Lift Kit Question
Old Jan 8, 2007 | 06:42 PM
Yakima5019's Avatar
Yakima5019
Lift Kit Question
Would the below lift kif fit my 78 Bronco. Anyway to make it work. My bronco has never been lifted. Thanks.
6 inch suspention lift
lift kit fits all
1980-1996
Ford full sized bronco and f-150
Includes:
Front coil springs, radius arm drop brackets, I-beam drop brackets, power steering pitman arm, 6 RC Hydro 8000 series shocks, u-bolts, and option of 3" rear blocks, add-a-leafs, and Sway-bar drop brackets
all you will need is extended brake lines and optional steering Stabilizer
Old Jan 8, 2007 | 07:02 PM
andym's Avatar
andym
Why would you think a lift kit, that specifies it is for a 1980-1996 Bronco, would work on a 1978?
No, it won't.
Old Jan 8, 2007 | 09:54 PM
Yakima5019's Avatar
Yakima5019
"Why would you think a lift kit, that specifies it is for a 1980-1996 Bronco, would work on a 1978?"
The question was. "Anyway to make it work". I've never lifted a truck and dont know jack about it.
Old Jan 8, 2007 | 11:06 PM
rollerstud98's Avatar
rollerstud98
your bronco is the old style still right, so your front axle is solid and you have the leaf springs where the 80 to 96 has the TTB front axle and coil springs
Old Jan 8, 2007 | 11:30 PM
bronco521's Avatar
bronco521
78-79 bronco's are coil in the front as well as f150's.
as to the original question,the front suspension is very different between the 78/9's and the 80 and up.you may be able to use some of the parts but i don't know.if you could get a suspension catalog and do some cross referencing of the part numbers this may be the best way to get answers.
Old Jan 8, 2007 | 11:48 PM
rollerstud98
thanks for correcting me, i wasnt entirely sure about it
Old Jan 9, 2007 | 10:40 AM
wileec's Avatar
wileec
They are coil but are not TTB
Old Jan 9, 2007 | 10:56 AM
andym's Avatar
andym
Wouldn't it be easier to just buy the correct lift kit? There's no easy way to make it work. If there was, the range of years would include 78 and 79.
Old Jan 10, 2007 | 09:05 PM
dwoodler's Avatar
dwoodler
The major difference is the length, size, and style of the radius arms and the associated brackets. I'm speaking with first experience on this one - check my signature. The 78 and 79 are identical.
