Offroad & 4x4
5 to 8 lug conversion axle length
Old Jan 8, 2007 | 03:41 PM
794x4390's Avatar
794x4390
Question 5 to 8 lug conversion axle length
Truck: '79 F-150 w/ HP Dana 44 front
I swapped in a rear Dana 60 awhile and have finally acquired the parts to convert the front to 8 lug to match. Except maybe the outer axle shafts which is where my question comes from.
I pulled the knuckles, caliper brackets, calipers, rotors, spindles, and hubs from a '76 F-250. The only problem is it has full time hubs, which I don't want to run. Because it is FT, the outer axles are really long and I didn't get them 'cause I'm pretty sure they won't work.
I do have a pair of $hevy 8 lug hubs that I can use but I think the FT spindles are too long (right?). Can I use my 1/2 ton spindles with the $hevy hubs (I know the bearings will fit, but will the length be right)? Do I need different spindles? Do I need different outer shafts? I have scoured Mr. N's site and everything else I can find but have been unable to come to a difinitive answer. Any help is appreciated.
Old Jan 8, 2007 | 05:29 PM
82F100SWB's Avatar
82F100SWB
Can't you just swap out the drive flange for a locking hub? I could be wrong, but I'm pretty sure that you should be able to just do that rather than change the whole wheel hub.
Old Jan 8, 2007 | 06:13 PM
794x4390's Avatar
794x4390
Well, I used to think so but the hubs on the donor truck have the drive plates bolted to the outside of the hub and the axle sticks out through it with a dustcap and snap ring. In other words, the axle protrudes through the drive flange past the outside edge of the hub. I suppose the $hev hubs might be deep enough to overcome the difference, but I don't think so. I'll see if I can find a pic of what I'm talking about.
Old Jan 8, 2007 | 06:28 PM
fishmanndotcom's Avatar
fishmanndotcom
are you talking about external locking hubs?
do they look like this... http://www.pirat e4x4.com/tech/billavista/60_front/Dcp_4510%20copy.jpg
OR this.... http://www.pir ate4x4.com/tech/billavista/60_front/im000057.jpg
(to get those links to work you need to copy and paste them in the address bar and remove the space, good ole FTE wont let you paste links to them even if you are being helpful!)
-cutts-
Old Jan 8, 2007 | 06:33 PM
794x4390's Avatar
794x4390
Apparently, it's a 60 or camper special hub like this:
http://www.pirate4x4.com/tech/billav...flange%202.jpg
Old Jan 8, 2007 | 06:36 PM
794x4390's Avatar
794x4390
Yup, it's the second one. I just found that pic when I was searching. So I guess I should go back and get the axles and buy some PT hubs. I guess they would be dana 60 hubs?
camodown
133
Sep 2, 2025 12:31 PM
Shake-N-Bake
35
Dec 20, 2015 07:48 PM
Kirbys73F100
May 23, 2013 01:06 PM
Stangrcr1
Jul 6, 2012 02:54 PM
kozak79
Mar 26, 2010 12:09 AM
