1996 F150 only one code left. I need help
Old Jan 8, 2007 | 03:39 PM
dpbrowne's Avatar
dpbrowne
I got rid of about 5 codes by doing the following:
1) Replaced EGR valve and EGR sensor
2) replaced the ICM (bought from Ford "the black one")
3) Replaced Mass Air Flow Unit
4) replaced wires and rotor
Now all I have is this (P0102 Mass or Volume Air Flow Circuit Low Input)
What am I missing? Dennis
Old Jan 8, 2007 | 04:11 PM
alxsnmr's Avatar
alxsnmr
I am not sure if it is needed, but did you get your computer reflashed after the Mass Air Flow sensor change?
Old Jan 9, 2007 | 12:04 PM
dpbrowne's Avatar
dpbrowne
Did nothing with the computer. How do I do that? Dennis
Old Jan 9, 2007 | 12:11 PM
Conanski's Avatar
Conanski
I'm not sure if he meant "clearing the codes" or not.. I'm sure he'll clear that up. In any event, if you have a code reader have you tried clearing the codes?
Old Jan 9, 2007 | 01:28 PM
dpbrowne's Avatar
dpbrowne
Yes I did but the P0102 code keeps returning. I disconnected the battery to see if that will clear the code. Will that help? Dennis
Old Jan 9, 2007 | 09:02 PM
alxsnmr's Avatar
alxsnmr
It depends on the MAF sensor, some manufacturers require a reflash of the computer by the dealership for the computer to recognize the new sensor. So are you sure that it was a bad MAF sensor?
Old Jan 10, 2007 | 09:07 AM
dpbrowne's Avatar
dpbrowne
I changed the MAF sensor because the code P0102 pointed to it. BNow I am totally confused. Whereshould i start looking? Dennis
