Predator hook-up question
Old Jan 8, 2007 | 01:56 PM
jaybe's Avatar
jaybe
Ok all you FTE Predator guru's......here's the question: I hooked up my predator to see if any codes were evident and the predator wouldn't power up. It was as if the power was turned off to the Predator. As I recall (it's been along time since I've had it attached) you just hook it up to the OBD port and the Predator "comes alive". Am I doing anything incorrectly? I went through the instruction booklet and I can't determine if I'm doing anything wrong. Any suggestions? Thanks in advance for any help.
JB
Old Jan 8, 2007 | 02:22 PM
raptor131's Avatar
raptor131
JB
check the cigerette lighter fuse it most likely is blown. i'm not sure what fuse it was. it is a 20amp . if it isn't then check with a volt meter at the obd2 port to see if you are getting 12v dc on any of the pins. if you are then i would suggest checking the cable tip oif the predetor to make sure none of those pins are bent or damaged
Old Jan 8, 2007 | 02:37 PM
jaybe's Avatar
jaybe
Now that you mention it I couldn't get my lighter outlet to work on a 12 volt plug-in (CB radio) I had my powerpoint occupied with a GPS. I'll let you know.
Thanks for the reply.
JB
Old Jan 8, 2007 | 03:31 PM
jaybe's Avatar
jaybe
raptor131-Your hunch was right, I did have a blown 20 amp fuse to the cigar lighter/OBD II. My Predator lit right up and showeed me that no trouble codes were present. I thought I was having a problem with my turbo or maybe fuel delivery as I was giving the truck fuel pedal but things were very slow to happen....as in no turbo. Maybe I was traveling through a worm hole or something but no problem with turbo since I got back into truck after shutting it down.
Thanks for your help. Good fix!
JB
Old Feb 6, 2009 | 07:33 PM
KRDiesel's Avatar
KRDiesel
Thanks, I thought my PCM was going out!! Lost lighter years ago, and always use power point. Love the SEARCH!! Rep added!
azfordman
Apr 22, 2006 10:51 AM
whitmo
Jun 12, 2005 08:10 PM
1wheel
Computer Chips & Tuners
Jan 15, 2005 09:42 AM
Bandit0594
Nov 11, 2004 12:03 PM
BagStroke
Apr 23, 2004 07:42 AM
