30k Service
Old Jan 10, 2007 | 05:08 PM
tex25025's Avatar
tex25025
It's every 30k you need to replace your tranny oil. I would be a little cautious about a shop that says you don't need it but every 100k. For a car maybe, but not for a truck that is expected to be hauling stuff and hitting some pretty good temps while hauling.
Old Jan 10, 2007 | 06:14 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
I would steer clear of the 100K shop and look elsewhere if you can
Old Jan 10, 2007 | 06:21 PM
ripnlips's Avatar
ripnlips
It didn't sound right to me either.
Old Jan 11, 2007 | 01:45 PM
jdadamsjr's Avatar
jdadamsjr
BB the two times I drained my HFCM - it ran out until I closed it cuz the two 3 liter bottles I had were full....
can't imagine the itty bitty fuel filter holding that much
Old Jan 11, 2007 | 02:12 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Wow... that is a lot of fuel to drain out.
Keep in mind that any water that MAY be in the HFCM housing will drain out first in the first few seconds... as oil (fuel) floats on top of water. The HFCM drain is the single lowest point of the fuel system.. and where water will collect. I would drain for no more than 1 minute to ensure all flows out then just shut it off.
Remove filter cap and replace the HFCM filter as required. My dealer tech told me that changing the filter does not remove or drain any water in the HFCM... so always drain first, then do the filter change.
Old Jan 11, 2007 | 05:19 PM
bigredtruckmi
Veteran: Navy
One thing I've learned is to try to do the fuel filter change with less than 1/2 tank of fuel. I get about a qt of fuel out.
Old Jan 11, 2007 | 06:21 PM
duffman77's Avatar
duffman77
Keep in mind though that if you stop the drain early and then take the fuel filter off, you are in for a bigger diesel bath out that end
ernesteugene
15
Feb 5, 2009 07:25 PM
afreemanmd
Aug 6, 2008 08:04 AM
chixdigit
Feb 5, 2007 11:26 PM
anollmann
2004 - 2008 F150
Nov 6, 2006 09:34 AM
birddog16
May 4, 2006 08:02 AM
