Sponsored by: Real Truck
Lighting my way back
Old Jan 7, 2007 | 07:42 PM
rmarley52's Avatar
rmarley52
Lightbulb Lighting my way back
When backing up my F350 dualy I can't see the area around the back tries. Does anybody else have this problem or have any ideas on lighting the area around my dualies?
Old Jan 7, 2007 | 07:49 PM
PHWLEE's Avatar
PHWLEE
There have been postings on back-up lighting. I am thinking about installing some auxillary back-up lighting and can imagine you could use them as well with the dual setup. Look around and you should come up with the thread.
Old Jan 7, 2007 | 08:47 PM
rmarley52's Avatar
rmarley52
Most of those are for lighting behind the bumber not the sides.
Old Jan 7, 2007 | 09:55 PM
capn kirk's Avatar
capn kirk
everyone has that problem i usually end up touchn the brakes n usen the red light 2 see
we put back up lights 2 square 2"X4" lights (look like fog lights) on my uncles excursions works great im gonna buy some soon
just go to advanced auto etc. pick up some kinda driving/fog lights wire em up 2 ur reverse lights n you'll be good to go we mounted em next to the frame hitch's mounts
Old Jan 7, 2007 | 10:03 PM
c.f.moore's Avatar
c.f.moore
I did as "capn kirk" suggested, with KC backup lights. I wired them into one of the upfitter switches, works great.
Old Jan 7, 2007 | 10:57 PM
Neil's Avatar
Neil
I saw a dually a while back that had clear 4 inch round Truck-Lite backup lamps (rubber mounted) installed in the bottom of the fenders. Looks like they should help quite a bit.
Old Jan 8, 2007 | 06:13 AM
Adventure's Avatar
Adventure
When we originally converted our van over to a dually, backing up was always a hair raising experience because you couldn't see the rear bumper since the fenders hid everything. But, after a while you do get used to knowing where the rear end is and adjust for it. Backing up with a little utility trailer is even worse because you can't see the trailer.
Old Jan 14, 2007 | 11:23 AM
rmarley52's Avatar
rmarley52
I have backup sensors that tell me that my bumber is close to something. The problem is seeing where my back tires are at night.
Old Jan 14, 2007 | 12:10 PM
powrstrkn''s Avatar
powrstrkn'
Put fog lites ahead of the rear wheels, so that they shine on the ground around the tires. Someone on here has it, I can't place it right now.
Old Jan 14, 2007 | 12:22 PM
hookd's Avatar
hookd
I will be doing the same thin under each back corner of the flatbed along with on the hitch area wired onto a switch in the cab so when I'm in town I don't blind everyone behind me and I can stop dragging around a flashlight when I'm hooking up a trailer.
Old Jan 14, 2007 | 02:11 PM
hosemandc's Avatar
hosemandc
I went to Napa and bought to small cheap floodlights that instal into the tailgate with rubber gromets. All you have to do is cut two I think 3 inch holes in the sheetmetal and pop them in. No screws backets or anything. Depending how high on the tailgate you locate them dictates the angle of the beam.
Old Jan 14, 2007 | 08:28 PM
redford's Avatar
redford
FTE Leadership Emeritus
All you have to do is train your wife to be a Monback.
You non-military guys probably don't know what a Monback is.......that's the person that gets out, stands behind the truck and says "Monback.................monback.................. ...monback............K"
Old Jan 14, 2007 | 08:38 PM
PHWLEE's Avatar
PHWLEE
Now you have me rolling on the floor.....
mech1
Dec 5, 2010 08:33 PM
makomaker
Apr 12, 2008 12:27 AM
jwgeorge
Sep 25, 2005 09:33 PM
LanceK
Dec 30, 2004 02:06 AM
jason99
16
Nov 21, 2004 06:20 AM
