No 4WD Hi
Old Jan 7, 2007 | 07:12 PM
markwolfe07's Avatar
markwolfe07
Unhappy No 4WD Hi
Decided to put in 4WD manually since I couldn't get the NEW Motor to work. Selector won't stop/click in at 4Hi just keeps turning past to neutral? If I turn it to 4Lo it clicks in and seems to work okay. I'm guessing it's a transfer case problem. Any suggestions???
Old Jan 7, 2007 | 08:11 PM
Rags's Avatar
Rags
It could be just a wireing problem at the motor or a bad unit altogether. If i'm not mistakeing there are tabs inside the motor assembly that stop it's turning at a set point.
There was a good thread on here showing a motor disassembled and the way it worked. from what you are discribing it sounds like when the unit was assenbled it was not timed correctly.
Do a search on transfer case motors in this forum.
