Help needed! Heater 93 E150
Old Jan 7, 2007 | 05:54 AM
s1120's Avatar
s1120
OK, so I got the lower panel out of the way on the pas side, and can see the heater box. I pulled the dash cluster panel, and pulled the heat controls out, and I also pulled out that panel on the top of the dash, and can see the vac motors for the vent, and defrost, but I am still lost!!
My problem is I have no floor heat, or defrost. the panel vents work fine, but nothing else. the fan blows, but no air is coming out. Looking at the top of the heater box, I can see the panel vent motor close, and the defog one open when I switch to defog, but no air comes out the defog vents. Im guessing I have something blocking it somewere.
Now before I go crazy, and tear the whole van apart, I could realy use some help.
What do I have to pull apart to try to get to the piping to check for a blockedge? I dont see anything else to pull except the whole dash board. I REALY dont want to do that. Is there a easer way? How do I get in there? What do I remove? Anyone have a picture of how the heating/vent system looks, to give me a better idea?
I realy need this fixed. I am trying to sell the van, but cant sell it in winter time without defrost.
Thanks for any help you all can give me!!!!!!
Old Jan 7, 2007 | 07:11 AM
ubereal2's Avatar
ubereal2
Are the vents powered by a cable, vacume, or electric motor "actuator"?
The actuator's are a small motor that move the flaps. Does the van have a "dog house" that you can remove that might give you some more headroom in you're search.
Bob
Old Jan 7, 2007 | 07:24 AM
s1120's Avatar
s1120
All the flaps, except for hot/cold, are controled by Vacume. The doghouse does come off, but it does not apear to increase acces any.
Old Jan 7, 2007 | 03:54 PM
subford's Avatar
subford
It sounds like your Vent Motor has vacuum on it all the time or the Vent flap is struck in the vent position.
The Vent Motor is on the front and should have a blue vacuum hose on it.
Here is a photo and the Vent flap is just above the word "IN".
http://i54.photobucket.com/albums/g9...cuum/DUCT1.jpg
Here is a photo looking into the duct from the output end.
http://i54.photobucket.com/albums/g91/subford/Vacuum/DUCT4.jpg
Vacuum Diagrams:
http://i54.photobucket.com/albums/g91/subford/Vacuum/1993EseriesVacuumLogic.gif
http://i54.photobucket.com/albums/g91/subford/Vacuum/1993EseriesVacuumLogic1.gif
Old Jan 8, 2007 | 02:25 PM
s1120's Avatar
s1120
Cool! Thaks alot I will check it out!
katzklaw
17
Jan 7, 2017 11:05 PM
JayzDaddy
Oct 3, 2016 07:11 AM
racin
1997 - 2003 F150
Jan 14, 2016 09:00 PM
truckrider814
Feb 28, 2010 05:05 AM
justjohnny38
May 4, 2007 10:04 AM
