engine swap idea
Old Jan 6, 2007 | 11:17 PM
Diesel nut's Avatar
Diesel nut
Smile engine swap idea
Hey guys, thinking of swapping in a 200ci 6cyl engine out of a 66 mustang into an 88 2wd Ranger with a 5spd. The Ranger currently has the 2.0L 4cyl. Wondering if the 6cyl will bolt up to the 4cyl transmission. Any info is helpful. Thanks, Casey
Old Jan 7, 2007 | 09:18 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
The 200 CID engine will not bolt to your transmission and the 200 engine is too long from rear face of block to front face of block to fit between the radiator and firewall. In general, the old Mustang engine is not a very good choice to swap into any vehicle.
Old Jan 7, 2007 | 09:23 AM
wendell borror's Avatar
wendell borror
Yeah, if your going to that much trouble to fab an engine in and it will need fabing, you might as well do the 300 I-6 and make worth the effert, You'll need to back up the firewall, or extend the frontend.
Old Jan 7, 2007 | 06:28 PM
Diesel nut's Avatar
Diesel nut
Thanx for the info guys I'll probably just rebuild the engine thats in it. Can I get much better than 80 hp out of this engine? better mpg? Best mpg was 24.5 before it blew. 5spd trans with 3.73 gears. Would like to up mpg as best as possible. any info appreciated. thanx, Casey.
Old Jan 8, 2007 | 02:20 AM
wendell borror
The only way to up mpg would be to go to a higher gear, like a 3:54 or so, but since it's allready down on power, probobly not a good idea. Try a good tune up, proper tire presures and maybe try synthetic fluids in the whole drive train - engine, tranny and rear diff. I use royal purple, it seemed to help.
