Mercon in Power Steering?
Old Jan 6, 2007 | 10:04 PM
Sport45's Avatar
Sport45
I've got a remanufactured steering gear and new hoses for my '83. I'll flush the pump good while I've got everything out. Is Mercon (Dextron III) acceptable to use in place of the Type F called for in the owner's manual? I'd like to keep the transmission and PS with the same fluid since I have lots of it, but will go with the type F if I have to. The steering gear doesn't specify any particular fluid, ony "manufacturers recommended fluid".
Thanks!
Old Jan 7, 2007 | 09:15 AM
srercrcr's Avatar
srercrcr
My answer would be "no". Dexron III and F are not interchangable.
Old Jan 8, 2007 | 06:22 AM
locknkey's Avatar
locknkey
Use the recommended fluid, or Power Steering fluid for Fords. You won't be putting much in it to matter in so much as the fluids you put in the transmission.
Old Jan 10, 2007 | 08:51 AM
Sport45's Avatar
Sport45
Thanks, I'll look for the Type F. The Ford spec number on the O'Reilly's power steering fluid I have doesn't match the spec number indicated in my owner's manual.
Old Jan 10, 2007 | 07:02 PM
srercrcr's Avatar
srercrcr
My experience is if it says Power Steering Fluid, that's it. I guess it's a hydraulic fluid.
But if it says Mercon or Dexron III, thats auto trans fluid.
Old Jan 10, 2007 | 08:03 PM
locknkey's Avatar
locknkey
I personally would not recommend any other Power Steering fluids other than the recommended Manufacturers recommendation.
It just cost too much to replace a Steering Sector GearBox or an Power Steering Pump because of a label that said Power Steering Fluid and wasn't manufactured for FORDS.
I once apon a time used Mercon III in the power steering pump...then 3 years later had to replace the power steering pump AND the Steering GearBox. It leaked out so bad, it wouldn't even hold any fluid. At a cost of 300,00 plus the amount of Lucas Steering Fluid (@10.00 for a small 16 oz size + 20 or so bottles) It cured me.
Old Jan 10, 2007 | 08:20 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Spec numbers can change, with or without known sideffects.
If in doubt cross check the spec numbers at a local dealer that will be willing to help you out.
Or ask the member numberdummy, he should be able to find out for you.
I would not use anything but Type F fluid however in the PS pump in these trucks, which is what the manufacturer recomends.
I do know in the 90's they changed over to mercon for PS pumps, but those systems were designed for it too.
So as a rule use what is recomended for the application and you should be fine.
Old Jan 10, 2007 | 10:43 PM
Sport45's Avatar
Sport45
I'll stick with the Type F. I figure it's still made to Type F specs. The generic power steering fluid I have says it meets Ford spec ESW-M2C128-C and D. My owner's manual only mentions Type F spec ESP-M2C138-CJ. (Maybe they didn't have dedicated PS fliud in '83?) I don't think the new hoses or steering gear really cares what fluid go in and there's no telling how much Dextron II, Mercon, and generic PS fluid has been put in but the pump's not leaking now and there's no reason to take chances. I'll flush it good with Type F then purge and fill the system with it.
Thanks again for all the advice.
Dean_250
Aug 29, 2014 01:34 PM
AmmoDawg
Jan 8, 2013 09:26 AM
UaVaj
Jan 9, 2011 06:04 PM
bigred66
Aug 21, 2010 03:38 AM
Redranger03
1983 - 2012 Ranger & B-Series
Oct 1, 2009 03:48 PM
