i need help
Old Jan 6, 2007 | 02:01 PM
02sporttrac's Avatar
02sporttrac
Post i need help
my right rear blinker works when my truck is in park and some times on the road. most of the time it does not work and the front right blinks really fast.
Old Jan 6, 2007 | 02:28 PM
Steina's Avatar
Steina
CO River Rat
Sounds like the filament in that rear bulb is getting ready to break; try swapping in a new bulb.
Welcome to FTE!
Steve
Old Jan 6, 2007 | 04:24 PM
Coastiejoe's Avatar
Coastiejoe
Ok, here is the test to this one. The 01 to early 03 had this issue. I have to assume you have a tilt column. If so, move the tilt wheel to a different location and see if the problem goes away and all works properly.
If so, you have the infamous wire harness to tight issue.
It is not hard to fix if you care to.
Old Jan 6, 2007 | 07:40 PM
Coastiejoe's Avatar
Coastiejoe
Tilt your column, if the light starts to work again, then you have the infamous "harness too short issue" that the 01 to the early 03 Tracs had.
There is a TSB on this but it will only cover you if you have coverage left on your Trac.
Old Jan 7, 2007 | 11:43 AM
02sporttrac
can i fix this myself by other means than moving the steering wheel. so that it works all the time?
Old Jan 7, 2007 | 12:54 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
You have to remove the steering column covers and repair the harness, then reroute it so it isn't "stretched".
Old Jan 8, 2007 | 07:47 AM
02sporttrac
thanks i'll try that out and maybe if i'm lucky it will work
Old Jan 9, 2007 | 11:44 AM
02sporttrac
is there another part that i need to extend it or just use the original one?
Old Jan 9, 2007 | 12:05 PM
Coastiejoe's Avatar
Coastiejoe
There is enough slack available by moving the OEM harness.
Old Jan 9, 2007 | 12:06 PM
02sporttrac
should i be able to do this or should i take it in?
Old Jan 9, 2007 | 01:46 PM
quicklook2's Avatar
quicklook2
if you try to do this disconnect the battery first so the air bag is disarmed.
i am assuming you have a manual and if you do not get one.
Old Jan 9, 2007 | 03:22 PM
02sporttrac
alright yeah i figured that i would have to unhook the battery but after that?
just get a manual and go from there?
Old Jan 10, 2007 | 10:50 AM
jhemker15's Avatar
jhemker15
Maybe you should take it to the best mechanic in burt on fergus rd.
Old Jan 10, 2007 | 11:38 AM
02sporttrac
i will if i want to get it jimmy rigged!
