58 f-100 help
Old Feb 24, 2000 | 10:53 PM
cbc's Avatar
cbc
58 f-100 help
I have a 58 f-100 I took the old 6 cyl. out and am going to put in a 302. It came out of a 79 ranchero. I wanted to use the old 3 speed trani but could not get the bell housing to fit. and sugestions on the corect one. Or am i going to have to replace the trani. If so could i go automatic. and how does the linkage fit with the stock stering colum. Help I am confused
Old Mar 3, 2000 | 09:29 AM
Trail_Rider's Avatar
Trail_Rider
58 f-100 help
>confused
You're probably going to have to go with a trans that's compatible with the engine unless you can find an adapter (Advance Adapters?). I would recomend an updated trans anyway because the old trans may not be able to handle the torque and power of the newer powerplant. If you want to stay with a 3 speed they are definitely available for the 302. As far as linkages are concerned (I'm not familiar with your rig) you should be able to use the stock shifter linkage from the column if you go 3 spd, and only use one of them for an auto
Trail Rider
Old Mar 12, 2000 | 06:13 AM
Bobs60F100's Avatar
Bobs60F100
58 f-100 help
cbc
I can't help you with the tranny. But I have some questions about the engine transplant. Have you actually done it yet? I'm putting a 302/C6 in my 60 F100. So far all I've done is take the front end off and remove the 223 and four speed, and ordered the motor mounts (Trans Dapt 4145's). Do you have any pointers for the installtion? Any help would be appricated.
Bob Wood
BOBWOOD536(No Email Addresses In Posts!)
Old Jun 9, 2000 | 03:46 PM
tman's Avatar
tman
58 f-100 help
I have also installed a '78 351m from a thunderbird into my '60 f-100. the problem that I have is I cannot get the correct wiring for the starter. I try to start it and the starter won't shut off. Any ideas?
thanks tman
Old Dec 4, 2000 | 05:31 PM
rusty 58's Avatar
rusty 58
58 f-100 help
I have a 58 f100 with a 1970 302 and C4 combo, do yourself a favour and pickup a tranny with overdrive, otherwise you'll be cruisin' at 50 mph on the freeway. (or you can change the dif - but the ford 9in is a good one) I installed a B&M mega shifter on the floor but their was a nice Lokar conversion in last months Classic Pickup trucks Mag.
Most important though is the anchors. Sort them out before you do your engine swap or you will end up where I am at the moment. My truck flies but it makes me extremely nervous trying to stop it. Its disc brakes for me!!
Rusty
Old Dec 5, 2000 | 01:43 PM
chenders's Avatar
chenders
58 f-100 help
>that I have is I
>to start it and the
>ideas?
What kind of starter are you using? This my sound silly but I've read treads where people were talking about using gm style starters with the solenoid attached to the starter. There is a wire that runs to the resistor on the side that goes to the coil. This is to give the coil a full 12.? volts during starting. I also know that there are two types of coils. The old style with three prongs (two large and one small) and the newer with four prongs.(two large and two small). Obviously, the big terminals are the leads to/from the battery and starter. one of smaller one is for the starter button or lead on your switch. The other, if you have the four, is connected to the coil. Since you have points, the starter doesn't stay engaged until you start the engine. Anyway I would check those wires to the coil to make a long story short.
Then again I could be wrong.
Good luck,
Chris
Old Dec 5, 2000 | 05:01 PM
ke6bnl's Avatar
ke6bnl
58 f-100 help
chickinabigtruck
Aug 21, 2011 12:31 PM
Glockem45
Sep 1, 2009 09:08 AM
Glockem45
20
Jun 29, 2009 07:17 PM
engineguy33
Nov 14, 2005 10:01 AM
McFord79
Feb 5, 2005 11:48 AM
