Will a 78/79 F100 351 W auto trany swap into a 70 F100 - no engine or trany with out much trouble? Is the drive shaft the same length? Any major obstacles that may be encountered? Thanks for the help.
Welcome to FTE!
So you have a 70 that you want to put a 351W in ?
The 78/79 never came with a windsor, it is probably an 351M.
You can do anything if you have the time & Money.
This would be better in the 67-72 forum as your truck is a 70.
The 351W is only an engine plus, the mated transminssion, it has nothing to with what Truck it was in.
