Need Help Fast!!!
Old Jan 6, 2007 | 12:33 AM
Homelessduck's Avatar
Homelessduck
Need Help Fast!!!
Ok, so Im trying to hook up my 4wheel drive.. I cant figure out how the bracket things mount to engage 4low,etc. The part coming from the 4x4 shifter.... 2 bracket deals... ( 75 f100 btw). Can anyone take a pic for me please? Or link me to a diagram? I need this asap!!!
Old Jan 6, 2007 | 01:39 AM
Homelessduck
Please! I need to get this hooked up by morning.
Old Jan 6, 2007 | 11:25 AM
Homelessduck
Please...? All I need is a link to a diagram, or a picture of yours...
Old Jan 6, 2007 | 11:53 AM
petes79f150's Avatar
petes79f150
You might try posting down in the "clutch, tranny, axles and transfer cases" forum in the "misc." section.
Pete
Old Jan 6, 2007 | 11:59 AM
Homelessduck
Thanks, will do!
Old Jan 6, 2007 | 02:42 PM
Mil1ion's Avatar
Mil1ion
Using "Help Fast" usually doesn't work.
One needs to put the actual Topic in the title.
Does this help?
Old Jan 7, 2007 | 03:49 AM
Homelessduck
Thanks man! It is acually a different setup tho. 8\. I think we determined that its a Np203, but im stil nt sure. It has shifing linkage thats alot different then most. Theres little, groove... notch type things that dis\engage... Its hard to explain.
Old Jan 7, 2007 | 05:09 PM
Mil1ion's Avatar
Mil1ion
I don't have any books that cover that year for the t-case
Try these sites.
http://www.gear-works.com/np.htm
http://www.high-impact.net/transmiss...ar/doubler.htm
Old Jan 8, 2007 | 07:45 PM
Homelessduck
Thanks for the help guys! I still have not found a diagram of it yet tho, nor have I figured out how its suppose to be hooked up. Im so frustrated!
Old Jan 8, 2007 | 09:48 PM
fasthauler's Avatar
fasthauler
Does this look like yours
Old Jan 8, 2007 | 10:02 PM
Homelessduck
See where the red is? Instead of having a hole directly on the bracket, mine has little notches, like fingers... 3? I think, or 2. Where the blue is, on mine that isnt there, the brackets hook up to different/single brackets that are directly bolted to gears. One bracket is straight, the other is bent weird, kinda like an *S*. I can get the two hooked up, but I cannot put it in 4low because the two brackets bind.Thanks tho!
Old Jan 8, 2007 | 10:11 PM
73f350sc's Avatar
73f350sc
Maybey he needs the diagram for the NP 203..I have one in my chiltons but no scanner maybey Dennis could look one up..from what hes describing id bet thats what it is.
-Chris
Old Jan 8, 2007 | 10:35 PM
Homelessduck
Man id so appreciate that!!!
Old Jan 8, 2007 | 10:40 PM
73f350sc's Avatar
73f350sc
Sorry for poor quality does it lok anything like this though?
If thats it ..I can take another more detailed pic for you as well
-Chris
Old Jan 8, 2007 | 10:46 PM
Homelessduck
Thats It!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
