Having brake problems
Hi I have a 1993 F350 4WD 7.3L and Iam having problems with my new brakes
I have replaced the front rotors, pads and calipers also the rear drums and shoes also the wheel cylinders and I have also replaced the power booster and master cylinder well this is the third master cylinder and I replaced the vacuum pump. The problem I am having is every time you step on the brake it will kind of stop the truck but then the peddle will fade to the floor I have bleed the brakes
over and over also put a power bleeder on it Iam getting all fluid no air. If the truck is off the brake pedal is fine but like I said when it is running the pedal fades to the floor.Also Iam not losing any fluid out of the master(like a line leaking).I cant fix the problem so I hope someone can help.
Thanks
Jeff
Thanks
Jeff
Ben there
This isn't going to help much. I've been through the samething. The truck stopped just fine, but holding pressure on the brake pedal, it would keep going donw. And I reaplced about everything that I could change, and was told by one of the "Older Guy's" that it's "The Nature of the beast" that it was the system that was in the truck.
Amish65F100
38
05-25-2017 11:10 AM
Fords412
16
11-17-2016 02:31 PM
myakkacracka
13
06-16-2016 11:33 AM
5Rangers
07-25-2011 09:42 PM
