Need HELP from the EXPERTS
Old Jan 5, 2007 | 08:48 PM
Wieckster's Avatar
Wieckster
I have noticed in the last two fill ups of biodiesel that I have got at the same station which is only 11% my truck is smoking all the time just wondering if its the fuel or something else? Before switching to this station I was getting Bio from a different Station and it wasnt smoking only ust the poof at start up ANY help will be good THANKS
CHAD
Old Jan 5, 2007 | 08:53 PM
powrstrkn''s Avatar
powrstrkn'
Having never used bio myself I speak only from hearsay, but I do remember some members on here saying that Bio diesel makes LESS smoke than dino.
That being said bio is also know to clean out the fuel system, so check your fuel filter, it may be dirtier than you ever expected.
Is it smoking white ? Black ? Blue?
Old Jan 5, 2007 | 09:07 PM
Wieckster's Avatar
Wieckster
It seems to be blue and yes thats what I thought that bio makes less smoke also
Old Jan 5, 2007 | 09:13 PM
ballbandit's Avatar
ballbandit
You might have an injector issue. If you know someone with a telstar tester, do a contrubution test to make sure every injector is right. Might just be a freek thing that a injector went bad. Just an opinion. Does the truck seem to be running the same?
Old Jan 5, 2007 | 09:19 PM
superpony18's Avatar
superpony18
blue would be oil. turbo, injector o-rings, just to name a few possibilities that I have heard, mine was turbo.
Old Jan 5, 2007 | 09:44 PM
jtharvey's Avatar
jtharvey
Bio will make less smoke, so the increased smoke is not normal, especially if it's blue. When is the smoke happening, at idle, under acceleration, during decelleration, all the time, etc?
Old Jan 5, 2007 | 09:51 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I would suggest changing the fuel filter and going back to straight diesel and see what happens. Blue smoke is no good so get rid of the bio variable and run a tank or two to see what happens. If anything, stop getting fuel from the place that started the problem, well at least where you first noticed it. Who knows?
Edit: I see you said smoking all the time so my post stands for now.
Old Jan 5, 2007 | 10:03 PM
Wieckster's Avatar
Wieckster
at idle and at acceleration the problem is it takes me weeks to burn off a tank or fuel since I dont drive it much because of work vehicle.The only thing else I didnt add was the new place bio is agri-biodiesel maybe that is why? It doesnt seem to run ok but man it smokes at the stop signs and it smells bad the fumes
Old Jan 5, 2007 | 10:07 PM
Tenn01PSD350
I would again suggest running the new out as fast as I could and switching. Just my 2cents.
Edit: BTW, are you certain you are not smelling CCV stuff and it is different? Nonetheless, check CCV tube and go ahead and switch fuel.
