Sponsored by: Real Truck
Draggin Brakes
Old Jan 5, 2007 | 01:11 PM
Charles Sneed's Avatar
Charles Sneed
Question Draggin Brakes
Brake seem to be dragging on 02 F-250 4x4 Power Stroke. With front wheels off of the ground both sides are difficult to rotate by hand. Is this normal? Just how easy should the wheels turn? I removed the right side pads and seem to be a whole lot easier. The vehicle has 55,000 and has at least 5/16 of pad left and when braking the vehicle doesn't pull to the right or left.
Anyone one have a clue?
Old Jan 5, 2007 | 02:20 PM
biz4two's Avatar
biz4two
Arrow
Welcome to FTE!
I would suspect the slide pins in the caliper brackets. They need to be serviced...
Here is an excellent link: http://guzzle.rbmicro.com/cu.html
Has a step-by-step...with pictures.
Good luck...
biz
Old Feb 19, 2007 | 08:24 PM
Charles Sneed
I checked the slide pins and they were in great shape. The piston in the caliper was sticking on the right side
Old Feb 19, 2007 | 08:44 PM
redford's Avatar
redford
FTE Leadership Emeritus
How are your hubs? Is the front driveshaft rotating with your tires?
