Need help withVIN number decoding
Old Dec 5, 2000 | 05:59 PM
52 f1 younggin's Avatar
52 f1 younggin
I have a 52 F1. The id tag is gone from inside the cab. I've heard that the vin number is stamped somewhere the cab mounts but I looked and I couldn't find it. After I find the VIN number I'd like to find something that will decode it to figure out what kind of factory options it had just for the heck of it. If you have any suggestions they would be greatly appreciated. Thank you.
Old Dec 5, 2000 | 07:47 PM
Kenny's Avatar
Kenny
The Vin number should be stamped on the left frame near the steering gear mounting bracket, and you can also check the clutch housing.
Kenny
Old Dec 5, 2000 | 09:21 PM
52 f1 younggin
I don't have the original clutch mounting stuff but where on the frame? Directly to the left of the steering gear box? Is it on the top or the side? How do I decipher what the letters mean in reference to what factory options came on it? Where can I go to find information on how to decode VIN numbers for early model Ford pickups?
Old Dec 5, 2000 | 10:29 PM
Kenny's Avatar
Kenny
I believe it is stamped on the top of the rail, but I'm not exactly sure as far as right or left of the gear box. I have a book that will decipher the vin number for you if you can find it. There are also shop manuals for sale on this site's store. I'm assuming you have no title for this truck? Unfortunately, your vin number will only tell you the series, which engine, the model year, which assembly plant, and the sequntial production number. The rest of the info would have been on your rating plate. This is a real long shot, but worth a look anyway. Check the underside of your seat. You may get lucky and find a card stuck above the springs with the same info your rating plate had. If it is still there, be very careful removing it as it will be very brittle. Please post back and let me know how you do.
Kenny
Old Dec 6, 2000 | 03:45 PM
ke6bnl's Avatar
ke6bnl
I have the frame seperate from the rest of the truck and the vin number on my truck is on the rt side midway between the front spring mounts. hope that helps. Ed ke6bnl>
>as far as right or
>I have a book that
>for you if you can
>me know how you do.
>Kenny
Old Dec 20, 2000 | 02:07 PM
ebrowder's Avatar
ebrowder
Check your glove box too!!
Old Dec 20, 2000 | 03:25 PM
ke6bnl's Avatar
ke6bnl
