Help.. Quick measurement needed.. Quickly!!!
Old Dec 19, 2000 | 09:21 PM
512's Avatar
512
Any 48 F1's out there with out a front end on 'em???
What I need to finish my IFS install is a measurement from the very front of a stock 48 F1 frame to the center of the first or second top rivet of the front crossmember.
I have a measurement of where to put the chubbychassis IFS crossmember.. by measuring from the front of the chassis to the front of the crossmember.. thing is, the previous owner of the truck cut off the front of the frame as he was planning on having the front end tilt up.
I have got the crossmember where I think it should be, just by eye.. but I'd like to see how far I'm off before I start welding tomorrow.
If you've got an F1 with out a front end on it and can see the top of the frame rail, and could take a moment with a measuring tape I would greatly appreciate it.
Thank You,
Scott
Old Dec 20, 2000 | 03:25 PM
ke6bnl's Avatar
ke6bnl
>out a front end on
>'em???
>a stock 48 F1 frame
>first or second top
On my 50 f1 the measurement from the front of the frame rail to the center on the first rivet on the top is 15 3/4 inches.
Yesterday my boy and I just finished welding in the Heidts front crossmember and hats. They call for centering the Heidts cross=member 17 1/8 in. from the center of the large hole for the front shackle support of the original leaf springs. When I checked this measurement from the location of the original solid axle it seemed to agree with these measurements. Hope to mount the accesories tomarrow if time permits. Then move on to the rear end to have a mobile chasis.. Ed ke6bnl ke6bnl@juno.com
>up.
>like to see how far
>welding tomorrow.
>out a front end on
>it and can see the
>Thank You,
>Scott
Old Dec 20, 2000 | 03:56 PM
jwcnj45's Avatar
jwcnj45
My 48 measures 15 1/8 " from center of the front rivet to the center of the outer most bumper bolt hole. The ends of the frame are not square cut but to the outer edge of the frame mine measures 15 1/2. Hope this helps .
Old Dec 21, 2000 | 05:48 PM
foxs55's Avatar
foxs55
s-man56
Oct 28, 2012 09:37 PM
F250Rob
Jan 5, 2011 04:30 PM
halfdone
17
Nov 23, 2005 04:09 AM
boilerbots
Jul 19, 2004 08:45 PM
RodgerDat
Aug 23, 2001 12:04 AM
