Suspension lube points
Old Jan 5, 2007 | 08:25 AM
Lushman's Avatar
Lushman
I have noticed quite a bit lately that even going over a speed bump I hav alot of creaking noise. I looked for grease points or zurk fittings, but didn't see any. What type of lube should I use for the suspension points, ie spring mounts, torsion bars, shock mounts, etc silicone, white lithium grease ???
Old Jan 5, 2007 | 09:52 AM
Calli's Avatar
Calli
Assuming you have front leaf springs, check the rear of those. The one spring rides on an isolator pad that wears out or sometimes slides to the side. Otherwise I spray silicone on all rubber attachments. The tie rods have zerks. Carroll
bigred66
Jun 8, 2010 09:11 AM
51merc
Jul 11, 2008 05:05 PM
1saxman
2004 - 2008 F150
Oct 15, 2007 04:58 PM
dionysius
May 6, 2007 03:45 PM
